WOT fuel pressure...should it drop?
Old Sep 14, 2006 | 09:08 AM
PewterZ28's Avatar
Default WOT fuel pressure...should it drop?
This is a totally separate issue from my other thread.
Once we had part throttle tuned to our satisfaction, we decided to hit WOT briefly just to see how close the air/fuel was. Result was 14.0, pretty lean. Next I decided to hit it one more time and watch my fuel pressure gauge to see what it does upon going WOT. Result was it dropped from about 61.5 to 55.
Is this normal?
Old Sep 14, 2006 | 09:22 AM
Doc's Avatar
Doc
What size of fuel injectors do you have?
Old Sep 14, 2006 | 09:31 AM
PewterZ28's Avatar
SVO 30's.
Set up is G5X4 cam, stock heads, stock bottom, Fast 90/NW 90, Fast Fuel Rails, stock MAF, FLP 1-3/4 long tubes, 3" X Pipe into 3" bullets.
Fuel pressure sensor is at the end of the Fast Fuel Rail on the passenger side.
Old Sep 14, 2006 | 09:35 AM
jimmyblue's Avatar
Moderator
A rail mounted regulator should take out all of the
forward drops, so long as the pump is capable of
set pressure plus headroom. May be that you want
to add a Schrader before the reg to see if the pump
/ plumbing is fading on you, or the reg is just not
stiff enough.
Old Sep 14, 2006 | 09:44 AM
YellowToy/A's Avatar
I would try to set the PE down or the VE up to 12.7a/f. if u can get 12.7 I would not worry about it.
Old Sep 14, 2006 | 10:18 AM
TAQuickness's Avatar
stock fuel pump?
Old Sep 14, 2006 | 10:24 AM
PewterZ28's Avatar
Walbro 255 in-line w/ SpeedInc hotwire kit.
Old Sep 14, 2006 | 02:15 PM
you sure all connections are good (nothing loose on hotwire or ground)?
If it's any consolation, I have the racetronix set up and get a similar drop (63 idle, 52 WOT), but I'm not leaning out as you are. Been working on this one for a while and I still cannot explain my drop in FP.
Old Sep 14, 2006 | 03:26 PM
SmokingWS6's Avatar
A small drop is usually normal. Would an intank pump provide more stable pressure over a boost pump? As far as lean, WOT has not even been touched, afr will be fine once its setup.
