Gains with a full tune
Old Sep 17, 2006 | 04:24 PM
v-8's Avatar
v-8
Default Gains with a full tune
I just had a quick question, ive got a 1999 Pontiac Trans Am its got a 6.0l lq9 truck motor, patriot stage 2 heads, a custom grind lunati .595/.595 221/221 116 lsa, slp long tubes and Y pipe, Lid, ported tb and other small things. the car is on a stock tune right now. What kind of gains would be made with a full tune?
Old Sep 17, 2006 | 05:21 PM
HumpinSS's Avatar
you may see 15-20 and maybe better driveability and better gas mileage with a tune. The stock tune can potentioally be a little lean or rich and prolly in your best intrests to at least get it dialed in
Old Sep 17, 2006 | 06:47 PM
ZL1Killa's Avatar
i agree
Old Sep 17, 2006 | 10:14 PM
wait4me's Avatar
Drivability would be the biggest gain.
Old Sep 17, 2006 | 10:35 PM
jpat1023's Avatar
You would gain more than you think if you are still on the stock tune and have all those mods. With today's engines, when something gets modded, the computer needs to know about it to take full advantage of the mod. IMO, anywhere from 15 to 30, plus a big gain in drivability and gas mileage.
Old Sep 17, 2006 | 11:47 PM
ezrollin's Avatar
stock tune should be rich (at WOT) unless you did some modding that leaned it
Old Sep 18, 2006 | 12:39 AM
The Butcher's Avatar
And jpat1023, thats what MAFS are for. All you have to really do is disconnect the negative terminal, then reconnect it. Start the car, let it idle to operating temp, then drive it. Within about 100 miles the computer compensates for changes to intake by modiyfying timing and injector duty cycle. Speed density systems are kinda lame about "learning", but a stock MAF car can learn on their own.
Old Sep 18, 2006 | 06:39 AM
foff667's Avatar
LS1TECH Sponsor
the maf can only do so much.
Old Sep 18, 2006 | 09:00 AM
ZL1Killa's Avatar
the MAF does fine till it reaches its limits. why not use GM's billion dollar computer that makes the car run fine, let the MAF work its stuff.
its up to the person if they want to go SD or not or do whatever. I have no problem with my MAF or how good my car runs now with it.
lets not jump topics though.
15-25hp easy with mods if you haven't tuned it yet
