jets chip removal
Old Sep 17, 2006 | 04:44 PM
jaylouky502's Avatar
Question jets chip removal
when i was new to the ls1 i bought a jet chip and installed it not knowing how cheap there were LOL my question is can i remove the chip and hook it back up normal will it run fine or will it need to be re tuned?
Old Sep 17, 2006 | 04:56 PM
jimmyblue's Avatar
Moderator
Removing it will drive the PCM to go and readapt, to
unfake the fakery that is no longer there. Then you
will be back to stock. If you want to get the same
timing advance and fuel changes you had, then some
tuning work will have to be done.
Expect a little bit of stumbling and so on while it
readapts. Just have to drive through it so it gets the
leaning time it needs.
Old Sep 17, 2006 | 05:01 PM
ok thanks for the info
