Bucking problem
So I went and logged it last night, and I was looking at my fuel trim histogram, and it's bucking back and forth only between 2 cells. I don't know what that actually tells me, but I'm hoping someone can educate me about this, and let me know what I need to do to help or stop it from doing this.
It's a 99, cam, intake, headers, exhaust (or lack there of, lol), converter... just the usual stuff really. HPTuners is the software I'm using, and you are correct, it is lean in those areas. However, it was also lean in other areas and wasn't bucking.
The car has been tuned before, when I had a smaller cam, mid length headers instead of the longtubes, and a catback exhaust. I haven't changed much since then. I did add a little fuel to it, but before I try to address this problem, I want to learn more about what actually causes it and affects it and helps it.
This of course assumes you've steadied your spark in those areas and the spark is optimal.
On the matter of lean in other areas and not bucking, it has more to do with the effeciency of the cam. In your bucking range, you're in least effecient area of the cam (reversion effects).
