Wideband Discussion and Poll
If you look at the Poll results though, the LM-1 is the most used wideband by users of this forum.
Are there any solid reasons why the LM-1 is better than the LC-1 for use with a scan tool like EFILive? I think the LM-1 is more for portability and stand alone logging.
For me the WB is only a tool that sees occasional use,
random vehicles & times. So I had no interest in a hard
mounted design.
You want to be sure that any unit you buy, has a self-
calibration ability. Otherwise you can drift out with no
way to correct. Units that are always in the pipe are
harder to calibrate and some I looked at make no mention
of it at all.
There are a lot of issues or potential issues with output
fidelity for logging voltage outputs, ground offsets and
gain errors. See a lot of complaints about LC-1 especially
but anything that shares heater and signal ground is
likely to have some degree of error introduced. You can't
take these tools on faith.
I've used an LM-1 for two years with no problems, no overheating ect. The only time they get picky is if the voltage is lower than about 12.2v.
Overall, I like the compactness of the LC-1 and the portability of the LM-1. I don't have longterm data on the LM, but I can say that the LC is pretty finicky when it comes to electrical and heat.
I'm an aircraft electronics engineer and am familiar with this kind of technology. Most all of the WBAFR units are based on the Bosch Sensor which is inherently very accurate. Look for a unit that is packaged (sized) in a way that will be easy for you to use and that will interface easily with your logging hardware and software. Most of the units on the market today will work effectively for your needs.
Steve
