Could I use injectors, or get away with the stockers?>>
I just did a new WOT run with the stock injectors back to stock scaling as they should be with HPT.
At 5900rpms the Inj Duty Cycle% is at 90, then tops off at 97% at 6700rpms.
Anyone technically think I definitely need to change the injectors to larger ones? I think the threshold is 80% at max rpm if I remember reading correctly?
Could I gain any extra performance with larger injectors, or just a safety factor that would be built in?
