Learn me on some timing
Old Oct 18, 2006 | 02:28 PM
brad8266's Avatar
Originally Posted by DirtyJohn
Excellent analogy. Thanks!
Do we want to throw cylinder temperature vs. RPM into the mix and see how that effects timing/knock aswell?
I think heat plays a big part in knock/preignition, so I'm guessing you have to find a happy medium between enough advance in the upper RPM's to get the spark at just the right time, while avoiding preignition from the higher temps due to higher revs?
Temps play an huge part here, and that is also where your spak plug comes into play also. See too many variables.
Old Oct 18, 2006 | 02:34 PM
Xtnct00WS6's Avatar
Originally Posted by SSpdDmon
...Rather the time from when the PCM commands the spark, the plug fires (which is virtually instantaneously), and the time the mixture takes to burn. Electricity moves a lot faster than the burn rate of the mixture in the cylinders....
That makes sense. I've always wondered about that. Thanks.
Old Oct 18, 2006 | 03:02 PM
jimmyblue's Avatar
Moderator
Google for "spark advance crank angle burn"
turns up some nice material.
http://omni.cc.purdue.edu/~tlrobert/...nd%20knock.ppt
Old Oct 18, 2006 | 03:13 PM
brad8266's Avatar
Interesting
Old Oct 18, 2006 | 03:20 PM
ArcticZ28's Avatar
I'm sure that link tells the whole story, but the fact that I suck at physics and have never tuned anything prevents me from understanding 90% of those terms and equations. I already did google on timing/knock/kr/etc but wanted it explained from the LS1's point of view, but not necessarily biased towards it. I'm not quite sure how to say that. I was basically asking how our cars like timing, what causes knock, and how you figure out the timing you need, but then to generalize it. Brad and others have done a good job thus far on enlightening me. I'll take as much info as I can though.
Do you think spark plug indexing can play a crucial role in allowing you to run more timing with the heads available for our cars? Or would that be a minimal factor that should only be considered in all out race apps?
Old Oct 18, 2006 | 03:28 PM
brad8266's Avatar
Running more timing isnt always going to get you more power. Plugs should become an issue when you start making a good amount of extra, since the extra pressue will cause more heat. The best timing for your car can vary depending on the type of fuel you use as well as how much fuel is being injected. The idea is to get the combustion to occur right at TDC of the compression stroke, that gives max power. Now if you compare 105 fuel to 91 fuel, the 91 will burn faster, so you would need less timing so that the spark occurs later than with the slow burning 105.
The general idea is to adjust timing so that you get knock and then back off a degree or 2, that will put your cylinder combustion right about at TDC. If it knocks you know that it combusted before dead center, when you back off till it doesnt knock you are damn close to TDC combustion.
Old Oct 18, 2006 | 03:40 PM
ArcticZ28's Avatar
So is it fair to say you want to run the most amount of timing possible for the most power, or the least amount of timing possible for the most power. Say, you get knock at 30, back it off to 28 and get 430 peak hp then back it off to 26 and get 429 peak hp. Would it be better to run at the higher timing or the lower timing, or does it not matter (or just not work that way)?
Old Oct 18, 2006 | 03:50 PM
oange ss's Avatar
run as little timing as possible for power, if you make the same power at 26* as you do at 30*, there's no since in runnin extra, head design, cam design and fueling also play and a part in timin needs of an engine, a real shitty set up make take 32* of timing for power, but a well thought out setup may only need 24* to make the same power
Old Oct 18, 2006 | 04:00 PM
brad8266's Avatar
i agree
Old Oct 18, 2006 | 04:09 PM
ArcticZ28's Avatar
Can you explain the reasoning behind that running less timing when possible? Is it just to stave off possible knock? B/c from what I understand, if it's making the same power at both 26 and say 30 degrees, then that would say to me that the same forces are acting on the pistons at both setups and that neither one is necessarily better or worse. So, I don't understand why less timing is better.
Old Oct 18, 2006 | 04:23 PM
brad8266's Avatar
Its a little safer to run lower if the results are the same. Variables such as temps, and the environment can cause things to vary some so if you leave a little bit of cushion there it is more likely that you wont experience knock.
Old Oct 19, 2006 | 12:25 PM
  #32
patSS/00's Avatar
I understand the advance a bit more now, but am I wrong in thinking that retarding the timing allows for more compression of the mixture making it more vulnerable to being spontaneously combusted or is that just totally wrong?
That's a good point - that would be pre-ignition rather than detonation, since it's caused by something other than the spark. But I think in these engines high temps can cause this even without timing being more retarded than normal, and probably the only way to fix it is with added fuel or higher octane.
Old Oct 19, 2006 | 12:38 PM
  #33
SSpdDmon's Avatar
To get the most out of your motor, you ideally want to find the point where you can run the most timing and fuel while making the most power. Just because you see knock retard doesn't mean the motor can't take more timing. You first need to increase the amount of fuel delivered and check to see (on a dyno) if it makes a little more power and the KR goes away. There's a specific term for this, but I can't remember it off the top of my head. I must be losing it...
The term I was trying to remember was MBT (Max Brake Torque). MBT is what you're looking for when tuning your car. Basically, this is the point where adding more timing will not achieve anymore power. The easiest/safest way to find MBT is to start low and increase until you don't make more power. LS1's can achieve this with air fuel ratios anywhere from 12.2:1 to 13.2:1, which is why a loaded dyno (Mustang dyno) and real-time controls can make tuning spark a breeze.
Old Oct 19, 2006 | 03:45 PM
  #34
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Just to clarify, detonation is too much advance causing the burning force to hit the piston before it passes TDC, and pre-ignition is basically the mix lighting on it's own before the plug fires due to heat/pressure? So changing timing wouldn't affect pre-ignition (unless it was advanced so far it happened before the mix lights itself), and all you can do is add fuel/octane or reduce pressure/heat? And reducing timing or adding fuel/octane should help in fighting detonation?
Old Oct 19, 2006 | 07:18 PM
  #35
patSS/00's Avatar
Colder range plugs will definitely help with preignition. One problem with that is the colder ones all are made to have smaller gaps, and you can't adjust them beyond a certain range, probably not more than .050 (which works fine though).
Old Oct 19, 2006 | 07:59 PM
  #36
WS6 GreeN's Avatar
I'll bet theres someone out there who has tried spark plug indexing on an LS1
Old Oct 19, 2006 | 11:30 PM
  #37
ArcticZ28's Avatar
I have tried it, but at the same time it was my first time on cam install a while back, so the motor only lasted about 10 miles before a valve embedded itself in a piston I fubar'ed that one up pretty bad, so no results yet.
