LS1 and Megasquirt trigger wheels
Old Oct 20, 2006 | 05:59 AM
pugwash's Avatar
Default LS1 and Megasquirt trigger wheels
Hi All,
This is my first post on here and i'm extremely happy to find you guys- there are about 50 people in the UK who use the LS1 so tech is in very short supply!
I am installing an LS1 into an 4x4 racing truck, and will to use MegaSquirt (using the Ford EDIS system) to control fuel and spark.
There seems to be an issue with trigger wheel positioning on the LS1- the internal trigger doesn't seem to be useable without replacing (and i really do not want to drop the crank). However the nose of the crank doens't have any sort of woddruff key which would hold the trigger wheel in position if i used an aftermarket 36-1. i have found one post on the whole of the net (on here) which shows a solution but i can't really see how it was done.
So, how can i stick a trigger wheel on an LS1 crank and make sure there is zero movement on the trigger wheel? Also does the VR sensor fit nicely to the front of the block- are there any mounting holes?
[please note- i don't actually have the LS1 to look at yet- it is being shipped from a company called Clevelan Pick-a-part as we speak]
thanks
James
Old Oct 20, 2006 | 04:33 PM
Happy Jim's Avatar
Can't help with the trigger wheel question I'm afraid. However I'm intrigued why you'd want to go MSnS when you could just get HPT or EFI Live and control just about everything you'd need (and less messing around )
Just a thought and not meant to disrupt the post.
Rgds
Jim
(also from the right side of the pond )
Old Oct 20, 2006 | 05:03 PM
kp's Avatar
kp
You can use an ATI balancer and buy one of their crank pin kits. The ATI serpentine balancer has a 3 bolt face and shoulder the same as a SBC and you can bolt an external trigger wheel on. You will have to make your own bracket for the pickup of course. About 700.00 or so USD.
That all gets pretty complicated, honestly use the stock 99+ (98 will work as well but the 99+ has more optins for forced induction if that matters) computer and engine harness and you can use EFIlive or HPtuner and have a great ignition and SEFI. Stock LS1 PCM and ignition is on quite a few 1000+hp cars, if its forced induction you can get 2 or 3 bar cutom operating systems and just speed density as well.
I have played wit the megasquirt and its a neet little box but nowhere near as sophisticated or hardened as the stock LS1 PCMs. If you are buying a pullout LS1 make sure and get the PCM and harness, if you can wire up a megasquirt you should be able to de-wire the stock engine harness without a problem.
Old Oct 21, 2006 | 12:53 PM
pugwash's Avatar
thanks guys,
unit is being used for off roading and lots of torque.
like the Megasquirt stuff because i have used it before and i can get aprts in the UK!
Hey Jim- what's the Cob? GD? Dax? engine? are you in the Cobraclub? i post on there as pugwash too although i don't post much anymore- not quite onto a cobra yet.
whats all this efi and hpt stuff then- any good links which explain it all?
Old Oct 21, 2006 | 01:15 PM
kbracing96's Avatar
thanks guys,
www.EFILive.com
www.hptuners.com
Are both tuning programs for the LS based vehicles using the stock computer. Both are VERY powerful and give you a lot of tunability.
As for the Megasqurit, it a neat little fi controller as well. PM Brains on here, he was working on a solution for it to fire the stock LS1 coils.
Old Oct 21, 2006 | 04:14 PM
Happy Jim's Avatar
thanks guys,
Hi, it's a GD I post as Happy Jim on Cobraclub as well.
I was thinking of MSnS while I was planning my transplant, however once you get your nose inside the capabilities of the GM PCM it's errr pretty damn good! I went for EFI Live in the end (software and interface cable/black box) along with a wide band controller from Innovate, threw in a different cam (and some other bits) - tuning has been easy so far (the M4 is my dyno ).
Rgds
Jim
Old Oct 22, 2006 | 04:11 AM
pugwash's Avatar
Thought i recognised your tag name! In fact i've got a funny feeling that we talked about 3-4 years ago- i can't beleive there's another chap called Jim in Wokingham who has a GD!
the problem i have is that the car is going to be used in extremely hostile conditions- it is likely that the ECu will get very battered and probably soaked. MS will allow me to cheaply carry a spare ECU in a waterproof container and swap them in minutes. Also 2 MS ecus cost less than the EFI software which is good. so i think i'll stick with Megasquirt- certainly if this LS1 was going in a Cob (i'm building a GD next year hopefully- it's been on the cards a while though- quite taken with a T70 at the mo!) then i would use this EFI stuff though.
Jim- what have you done for CATs- does Andy B at GD supply them? if so were they expensive?
Old Oct 22, 2006 | 03:30 PM
Happy Jim's Avatar
Far as I know I'm the only Jim with GD in Wokingham (que 30 others ). Cats, didn't bother with them as my GD went through SVA with an old RV8 motor (3.5% CO test) therefore I can breeze through the test without Cats now , Andy does them, just not sure how much they are though.
Cheers
Jim
