any dodge experts here?
If I had access to the repair manuals like I did, I could get you the pinouts and anyone with DealerConnect access can attempt to retrieve them also, but I believe 98 is the cutoff now for "online" help.
Brian
This turned out to be a bad PCM. I got ahold of the pin outs and the pcm wasn't doing anything, it had power to all the correct pins and good grounds. I had a hell of a time getting a pcm for this thing, every company I talked to said that the one I need is no longer available, they all could not get any more good cores for the one I needed. I called countless junkyards and no luck there either. I finally got a reman one through ECU DIRECT. They were very helpful and If anyone has trouble getting a pcm give them a call. Thanks for all your help.
