Running very rich at idle??
(just could not find the right smile)
What he said is exactly what you need to do. OLSD tuning will help as well with a BIG cam. Narrow band tuning (O2's) suck for looking a FAT idle conditions.
Yes it is. I have the FAST dual sensor wideband that I am going to try to install this week. The car has been tuned WOT so I am not as worried about that. It just seems like it needs a little changing on the low end.
very fat place in the EQ vs ECT vs MAP table (OLFA).
This is your cold running (over)enrichment. You need
to skinny down the mid-MAP (where you idle, and
below) cold enrichment to something more sensible.
This should also take out a lot of surging at idle.
The air shoot-through from that cam into the exhaust
is going to hurt your fuel trimming accuracy. This is
where some of the closed loop idle trim error will
remain, even if you fix up the VE table (which it will
need plenty of, on up to 2000RPM).
Between those two you are overfueled both by
command (EQ) and error (VE), further depressing
MAP and driving you even deeper into it.
Idle at >800RPM with that cam or you'll have even
more of a fight.
On the other computer I have a pretty good TRex VE
table; I know I've posted it here before but I will
try and dig it up for post.
The car will not idle upon initial startup, after like 30 seconds of keeping it alive it is fine. I have an MTI x1 cam. Idle is set at 800 i'm pretty sure. It fouls plugs but my wideband is telling me that the car is running lean at idle. idk its a huge disaster that i've been trying to solve for the past year and a half. Any help would be appreciated , thanks a bunch!
Oh btw the heads are stock, everything else in the sig is correct.
old HPTuners .bin format is not supported and zip'd
is still too big for that format limit. So I have to go
find a file host. Or you can PM me an email address
that can take a 800+KB attachment. But I want to
get it hosted for general, anyway.
