LC-1 Voltage at 0??
Thanks.
Bill
Bill
You've probably tried this but did you try to just reprogram the analog outputs? http://www.wbo2.com/lsu/
You just need to look around in that document. You can find a whole host of vehicles that run that same sensor, connector and all. Yes if you buy full retail from Innovate a "Wideband" sensor for a LC-1 yes they have to eat too.
Read the article, sounds like you might have a hairline crack on the pump cell. I have been thru this baloney and it is easy to replace. Good luck Bill.
Thanks for the article though!
Thanks for the article though!Bill
Thanks,
Bill
Bill
Bill
So with the LC-1 Programming gui software you set up a flat voltage on both channels, and you don't see that voltage on either of the LC-1 outputs...?
If that happens, and the LED still flashes and comes on steady, then sounds like the ADC chip inside the LC-1 is fried...
Check both LC-1 outputs for shorting to ground or power.
Contact Innovate about that, they should be able to fix you up.
Cheers,
Joe
Cheers,
Joe
Do they repair them or just sell me a new controller?
I will do some more checking first just to make sure it is not shorted
somewhere.Thanks for the help Joe.
Bill
