LS1's with a tune come in
I tend to learn better by looking at others tunes and seeing what they changed and then looking up why. The only guy that posted a tune was a beginer. Lets see what a "REAL" tune should look like.
Stoichiometeric AFR
Scroll down a little ways where is actually discusses AFR.
There is nothing wrong with me trying to compensate for advanced timing by adding more fuel to prevent knocking. Is there a better way to do it...I'm sure there is. Have I gotten to the point where I know exactly how to do that??? Not yet, but like I said before...at least I'm trying.
I'm sure at one point, y'all were the "noobs" at this and had people questioning your judgment on a tune. Instead of basically calling them an idiot, why not offer a firm piece of advice that would help them see what they had done incorrectly and then how to fix it.
Stoichiometeric AFR
Each have thier benefits, and each have thier downfalls.
One rule of thumb, If you didnt change it, then it probably shouldnt be messed with.
So dont screw with the IFR if you didnt change injectors, or dont change MAF if you didnt mess with the pre maf airflow.
You say that if I change my stoich, then I'm running rich at all times. This is not true.
You say that I don't know what I'm doing even though I showed you mathmatically that with the ethanol in our gas, we can change the value and not cause problems.
Then, I'm told that I just got lucky... Well, I don't think so.
My cruising AFR is around 14.3 - 14.9 and even into the very low 15s when I'm giving hardly any gas on the highway. As I start to give it a lot of gas, it drops down towards the 13s. When I floor it, it drops to the 11s for a brief second and then climbs back to the mid 12s and holds steady...NO KNOCKING.
My car pulls very strong, I'm not getting any knock and none of my sensors are freaking out...no knock retard coming on, even at 70 degrees out side with my timing advanced a lot.
If the computer Commands a set value when in closed loop it will use 02 feedback to get the desired value.
From what I can see, based on my tune, when I hit WOT, the car is targeting that number...the wideband is saying so. Granted, it's about 4/10th of a point off, but I suppose it's better to be on the rich side than lean side.
If you increase the spark, you should increase the fuel right? Is that not what I have done? Would not having cats contribute to anything?
From what I have read in other post, you most likely have your tune working right but you had to mess with a lot of other factors when you lowered the afr. Some might say its wrong, it does not matter I guess as long as your happy with it and you feel your car is running safely.
With help from RussK on HPT site, this is my most recent tune. I dont think it can be made any better until I get a w/b 02. Good luck with your set up and let us know what you do at the track and dyno.
It was mostly MeentSS that was doing all the smack talk. I never once told "martha" to install this tune on his car, "he's going to love it" sort of thing. He asked to see examples of tunes for our cars and I showed him one. Doesn't mean he is suppose to use it and yes, I agree, what may work well for one person may not work well for another.
In my original reply to this post, I said i created a "beastly" tune for MY car, and then I uploaded it so martha could look at it and review. Then I start getting all this flack about "here's what's wrong with the internet...morons claiming they know stuff and offering advice when they don't know anything about anything" kind of crap.
Like I said, I'm new to this stuff, but I'm learning and I'm trying. I never asked anyone to develop a tune for my current setup because I'm too lazy to do it myself.
I disagree with what the majority of these guys have said about tuning my car wrong. The fuel I use anyways, is an Ethanol blend so I don't see anything wrong with changing the stoich. Based on the numbers I got using the Wideband, (which is installed correctly) the car is 100% FINE!
I think the biggest problem you'll face when changing stoich is that it intermingles will all your other tables such as PE multiplyer...currently with that stoich afr set to 12.8:1 your multiplyer at say 4000-4400 is 10.77:1, and at peak hp on your car ~5600 rpms your commanding 11.07:1 afr.
Now I don't speak for all of us out here, there are some that tuning using the IFR/pe tables or others, but generally to make it I guess you can say easier on ourselves we usually aim to get our commanded to equal our actual afr...its a simple process & really doesnt take much if any more time at all.
Im glad things are working out for you & hope they continue to work for you & its great your thinking outside the box, but if you know your shooting for a 12.8:1 afr why setup your commanded to be 11.0:1? Anywayz happy tuning.
Bill
ps-im sure we'd all love to see any logs you have to see how everything else in your tune is working together-this is not a bash, personally I've never changed stoich so I would love to see its affects on trims, IDC & so on.
