knock sensor failing my emissions test?
not ready:
catalyst
evaporative system
sec air system
O2 sensor
H02 sensor
EGR system
Unsupported:
Heated Catalyst
A/C System
So, would a faulty bank one sensor do this or is there more underlying issues?
When knock sensors show low voltage its usually a short from moisture. When the sensor shorts out it usually damages the knock sensor harness too. Its not a hard fix but I replace both knock sensors, and the harness and then use RTV silicone and seal off the sensors from any possible moisture. Ive done a few like this and they never had an issue again. The first one i did was 3 years ago on a 98 and still going strong.
You can replace the sensors like i did on his car a few times and then you figure out the harness has been shorted as well. WHen i replaced the harness after both sensors were replaced we never had another problem. Its some kind of resistance in the harness that the sensors cant operate correctly on and will throw that code of low voltage.
Now I guess it is time for 2001's drive cycle, bwhaahahahahahahahahaha!!!!
Ill post the number tonight when I get home.
