KR in First Gear Only
Is this normal or am I likely getting a false knock?
I will post the logs tomorrow.
Also any ideas/explanation for the two significant drops in timing in first gear (see image below)?
IAT wasn't logged. Also I guess your fuel is getting hotter in the rails.
Extra heat causing detonation, therefore causing knock.
It could also be false knock. If you can get some race gas put a bit in and see if it goes away. If the knock stays its probably false and desentizing the sensor might be what you want to do.
My Turbo TA would false knock in first gear because the engine torqued over so much, the down pipe hit the frame.
Just a thought.
The OP got my drift and said so.
I with the car indicating 50 miles to empty I added 5 gals of 104 unleaded fuel and drove about 30 miles then ran the 1/8th while logging. The first 2 passes I had KR then on a hard burnout I heard a load thump and haven't had any KR since.
I am still not getting maximum timing in first gear but atleast i'm not getting KR. However I am still getting a significant drop in timing between 1600 and 2000 rpm while transitioning to wot which I can't seem to find any reason for. The recorded timing is significantly lower than what the low octane table calls for. I noticed that even with the 104 in most cases I wasn't getting to the timing indicated in the high octane table, is this normal?
Btw, I received the wideband o2 late on Friday so will have that installed and logging in a few days.
