Anyone tune a MAF yet?
Old Jan 8, 2007 | 02:01 PM
WS6HUMMER's Avatar
Default Anyone tune a MAF yet?
I wanted to know If I can tune the VE table on one day and the MAF on another. Is this OK or will it not be accurate? It takes me 3 log sessions to tune the VE table and by the time I finish the VE table its getting dark and the temp is dropping throwing of the VE table in SD mode.
Old Jan 8, 2007 | 02:11 PM
SSpdDmon's Avatar
Get the VE table close (+/- 2%), enable the MAF and tune for it. The VE table (or the tune for that matter) will never be perfect. You'll waste hours trying to get it that way. Closed-loop will keep the AFR at 14.7:1 once re-enabled. Keep it slightly on the rich side for part throttle. Then, focus on WOT. Again, it will vary from day to day. So target 12.8 instead of 13.0 to leave yourself a little wiggle room. Dial it in and call it quits. Don't sweat the small stuff...
Old Jan 8, 2007 | 05:52 PM
WS6HUMMER's Avatar
Thanks but setting the MAF fail back to 14000Hz & plugging up the MAF again on a SD tune wont make it go back into CL will it? I'm so dumb, please forgive my ignorance. If it does go back into CL then I can tune the MAF a week after tuning the VE table and it will be just fine right?
Old Jan 8, 2007 | 06:05 PM
SmokingWS6's Avatar
Closed loop will function with the maf on or off. If you did a standard ve tune, you were in closed loop. If your wanting true 'sd' mode then you'd have to disable closed loop by maxing out the CL enable temps. You'd then have to set your desired afr for all conditions.
Old Jan 8, 2007 | 06:06 PM
SSpdDmon's Avatar
Running a MAF or running MAF-less (speed density) has nothing to do with open or closed loop. That's simply the method the PCM uses to determine current airflow, which is then used to determine the amount of fuel required based on inputs from the other sensors (IAT, MAP, etc.).
Open loop means the O2 sensors are not being used. It's a linear fueling process. The numbers are calculated and that's the end of it. When the PCM starts adjusting fueling based on the O2 sensors, you're effectively bending that linear process into a loop (aka closed loop).
You don't go back to closed loop until you reset the temps in the Close Loop Temp Enable table....regardless of whether you're running a MAF or not.
Old Jan 9, 2007 | 08:17 AM
WS6HUMMER's Avatar
I did an Open Loop Speed density VE tune using a wideband and logging for VE AFR error%, It's the one Bill Henn submitted for HPTuner's help file. The way this tune works is you put the car in SD mode by disabling the Fuel Trims, MAF, and a few other things. Once your done you can leave the car in SD mode or copy the VE tables you just tuned (my car has 2) and paste the them to your regular MAF Tune. It's a little more complicated than what I'm making it sound but you get the general Idea.
Old Jan 9, 2007 | 12:27 PM
WS6HUMMER's Avatar
Right but the numbers the PCM's using to calculate fueling are the numbers in the VE table cells based on the amount of incoming air. Right? If I understand this right then it would be best to tune the MAF the same day you tune the VE table because the miniute the air changes the VE table becomes less accurate throwing off the actual amount of MAF error % I log right?
OK now that you posted this, I understand that even though I re-enable the MAF I still will be getting my fuel calculations from the VE table only and wont ever use the narrow band O2 sensors or fuel trim learn until I set all that stuff back.
Bottom line is, it would be better to tune the car's VE table and MAF on the same day in the same weather conditions. Otherwise it would be inaccurate..........Right?
Old Jan 9, 2007 | 03:48 PM
SSpdDmon's Avatar
It would be best, but not 100% required. Again, it needs to be close. Not dead-on ***** accurate....and yes, that's an industry term.
No. Again, the MAF has nothing to do with open loop. The VE works alone in speed density (no MAF) to calculate airflow. If the MAF is enabled, you're not in speed density. You're using a combination of the MAF & VE below 4,000 RPMs and the MAF above 4,000 RPMs.
Old Jan 9, 2007 | 04:47 PM
WS6HUMMER's Avatar
OK I see, thanks I understand that now. What about PE, I understand that it is calculated by the MAF right?
I did a VE SD tune and pasted the corrected VE tables to my old CL/OL MAF tune, commanded 12.8 AFR (1.14 on the EQ vs RPM table) and now @ WOT I'm seeing 13.4. That's why I'm so interested in tuning the MAF now, I'm thinking that's now what I need to tune. Am I right in assuming that the MAF is what needs to be tuned so that I will get the AFR I command?
Old Jan 9, 2007 | 05:08 PM
12secSS's Avatar
Just re-enable your MAF and use the MAF AFR Error % histogram to put the fueling back in line. So long as you are -4% to 0% range for your fueling, you are good to go.
Old Jan 10, 2007 | 07:47 AM
WS6HUMMER's Avatar
Thanks again george!
