going into OL when mashing gas
Here is what im dealing with:
Frame - 2820
rpm - 722
TPS = 10%
MAF = 7.01 lbs/min
MAP = 10.03 hg
spark advance - 25
Duty cycle - 3%
Long terms - -12.5%
Fuel status - CL
Then the next frame
Frame - 2821
rpm - 897
TPS = 54%
MAF = 5.24 lbs/min
MAP = 30.1 hg
spark advance - 8
Duty cycle - 17%
Long terms - 0%
Fuel status - OL-drive
The one thing that i think stands out is that the maf goes gets lower and the MAP gets real high...
And from some searching ive found that some people had this problem cause of tps voltage going too high from ported tb but i checked voltage and from 0-100%tps my voltage is 0.5-4.3, hitting 100% at 4.0 tps voltage
Any help here would be greatly appreciated.
O on second thought, would this be because of turbulance in airflow?
else seems sort of right. You might look at the MAF table and
see if there is anything abnormal there, which might translate
a rising frequency into a falling airflow. Perhaps log MAF freq
as well as the reported airflow number.
Thanks for the help.
