How is it possible idel
Old Jan 26, 2007 | 04:37 PM
yobabiesdaddy2001's Avatar
Default How is it possible idel
How is it possible that the car idels good after you start it, but it cant seem to find the idel after when crusing, coming to a stop.
Old Jan 26, 2007 | 04:54 PM
Tordne's Avatar
Airflow tables need to be corrected I'd say. If the desired airflow table is too high you'll get a hanging RPM, too low and it will dip and almost stall.
Old Jan 26, 2007 | 04:56 PM
Default cool
how do i correct the base airflow tables and what am I looking for if I have to do a log file
Old Jan 26, 2007 | 04:59 PM
Tordne's Avatar
Each tuning software may have their little tricks. Basically what you are looking to do if set the values in the base airflow (or whatever the table is call in your tool) to be the amount of air that the car is actually using at the various ECT temps.
The process usually requires you to log a PID which shows airflow in Grams/s (or whatever units you use) from cold start to full operating temp while stationary.
Makes a good difference though
Old Jan 26, 2007 | 05:14 PM
Great explanation, now I am starting to understand.
So what your saying is I need to find out exacty what the car is flowing exactly.
Example from one of my logs =at 68 fairinheit the car 12.41 g/sec, but on the Base Runnnig Airflow (idle airflow vs Ect) at 68 degrees it was calling for 15.07
Old Jan 26, 2007 | 06:54 PM
RedHardSupra's Avatar
surging is overfuling. if you're suging, decrease respective VE values, until it idles smoothly.
remember that if you have a cam with overlap, your readings at idle are going to be very lean, yet you're going to be completely overfueling, so you cannot always go by the wideband.
Old Jan 28, 2007 | 04:22 PM
ninobrn99's Avatar
that is one thing ive learned. its a PITA. I have a similar issue as you. When coming to a stop and taking the car out of gear, sometimes my idle dips down to 200 and then comes back up to idle, but then that isnt 100% stable either.
Old Jan 28, 2007 | 06:29 PM
Do you have a tuner?
Old Jan 28, 2007 | 08:34 PM
ninobrn99's Avatar
mmm hmm.. me and HPT
Old Jan 28, 2007 | 10:10 PM
I kind of got mine to settle down a little. I had the IAC maxed out. I bought a new throttle body that was pre adusted wrong.
Old Jan 28, 2007 | 10:12 PM
Rhino79's Avatar
In my experience, I have had good succes setting IAC counts to about 60, getting the Desired airflow accurate, and then if you are still surging, try raising the throttle cracker enable/disable speeds as well as lowering the throttle cracker table, if the values in that table are too high, the pcm will fight to try to get the rpms down to the desired level. I like to set the enable speed to 10 mph and disable to 9 just to try to see if that helps.
Old Jan 29, 2007 | 05:42 AM
I was thinking about doing the same thing!
I logged my injector pulsewidth last night and notice that right before the car switches over into the mode where the car is under 3mph, the IPW goes to 5.9-6-9 etc.. under no load, so I think its is loading up. If this is the case how do I correct it.
Old Dec 6, 2007 | 08:59 PM
zmonsterjb's Avatar
what are iac counts
