Cam Tuning Questions
Dick
hahah ya serious??? Have you obviosly tuned your own car??
How far is Geneva from Lombard???
If you really intrested let me know??
EDIT: You are 18 miles from me.....
All M6 cars came with a 3.42... but yes i think gears should help out a bit...
ahh my bad.. sorry..
FWIW, I have my idle at 850 going down to 800 when fully warmed up. No problems.
i had 28* of timing had a lot bucking backed it down to abou 20*i beleive... What gear are you running as well?
And i really want my idle at 850. at 950 you can not hear the lope of the cam all that well
Timing at low airflow on my car is way above 28*...at high airflow, it goes down to about 26* max, but I've shaped the curve to my liking. What he's dealing with is a 3D map. You'd definitely need more information before you would be able to figure anything out.
yes that is correct... i am gonna try to get my file and see if i can work on it
28* where?
Lost my original pull that gave me my numbers...
FIRST PULL WITH CAM
I FORGOT WHAT THIS GRAPH SHOW
NICE A:F
CORRECTED NUMBERS http://smg.photobucket.com/albums/v6...231237idle.flv
nice i would love to get an 800 RPM idle.. that is in the works
