Cam Tuning Questions
Here are my questions, i already had to take the car back 2 times now.. And i still do not think that it is right!
Any help would be greatly appreciated..
Here are my problems
1) at around 1400 - 1600 RPMs the car will buck. That is annoying
2) at 2000 RPMs in 4th or 5th gear you give the car 1/2 - 3/4 throttle and the car will hesiatate for a second (it has to hops to it) then it will go..
Those are the only 2 problems that i have that are repeating. I took the car in b4 for the odle hang... that was fixed.
I also want to idle to be at 850. it is set at 950 saw it on the computer while my car was running hokked up to the OBDOII.. But the tuner said that he tried to lower the idle and that at warm/cold starts the car would struggle for a bit to come alive....
Any ideas on what i can tell my tuner? Patrick G recomended that i post it here. He also gave me some suggestions.. But he said more help to come here.. Please help. I can not deal with the bucking.
And here is what Patrick G had told me in realtion to problem #1 and #2
PLEASE HELP!!!!!!!!!!!
In the first post i added the graphs.. and i will put them here too
Lost my original pull that gave me my numbers...
FIRST PULL WITH CAM
I FORGOT WHAT THIS GRAPH SHOW
NICE A:F
CORRECTED NUMBERS Last edited by TORCHD 02 TA; Feb 16, 2007 at 08:30 PM.
Yeah it is a PITA to keep running to the tuner. he is only 45 mins away but still. i have to worry about getting a ride back and a ride there...
I don't know how to tune my own car
Bucking is a fairly common issue with cams with alot of overlap & I havent heard a clearcut way to fix it...i hear alot of "well its your fueling" or "its your timing" or "its your airflow" if someone finds a clearcut cure that works everytime I'd love to hear it.
As far as your hesitation issue...I ended up changing a couple of the idle tables and was able to give myself a hesitation issue...just turned them back a little until it went away...not sure if thats your issue or not, but possible. To get a cam someone else chooses for you to run right isnt always easy, thats why most shops have their own cams they specialize in because they have a consistant tune/result. Alot of shops go for the cams with less overlap which usually means they are easier to drive which is what many people prefer. :shrug:
Anyways good luck, and we all started somewhere with tuning
Me=1 shop + 4 trips back & forth 60 miles each way=HPTuners FTW
well, i was thinking that a 4.10 would get rid of the that problem too... Why do you think that a cam was not the best mod for me then? I knew all the risks going into it. Just thought that tuner with all his experience would be able to get the problem solved
You did not have stall with your A4? Cuz i know someone with a 3600 stall and has 2.73s.. no bucking b/c of the stall.. but that is another story.. And it does seem that these M6 cars are picky when it comes to tuning.. IT NEEDS TO BE PERFECT! So either i talk more to the tuner or i get a 4.10.
Going back to bucking.. 10* is not that much??? i have heard the same thing. fuel, timing and air.... I chose my cam with some help with Patrick G and i did a TON of research.. as far as the hesitation... well i hope that it is in the idle table to help....
LOL at my exhasut threads.. that there is an easy fix though
But i did do the research on the cam.. again it is a tunning problem that needs to be addressed IMO..
I will talk more to the tuner to see if he can help more..... Man i would not know where to start if i were to get my own software.. i would be afraid i fry the PCM
you thought i asked a lot of cam/exhasut questions... what and see what questions i would ask if i got my own SW
The other option is to have him try and fix it with the throttle cracker or throttle follower tables. If you add in a little more air through the IAC, that might help cure some of the surging. Just don't add too much or you'll get a cruise control effect.
Ok i will check my PMs.. And i will respond
