Whats a safe PE (no WB)
Old Feb 14, 2007 | 05:08 PM
Magnet's Avatar
Default Whats a safe PE (no WB)
Well i have no wideband and don't have anyway to check actual AFR. MY car is basically a stock car, just bolt-ons and a converter. While reading through some of the Blogs by redhardsupra he said HERE
10. "Undo the GM marketing department's lame attempts to keep the LS1 from a F-body lower output than the Corvette. Setting the Power Enrichment table universally to 1.15 results in a much more sane (than the overprotective stock) 12.7:1 air-fuel ratio."
I also noticed that on a preliminary transmission tune FOFF helped me with he changed the stock PE to 1.2 across the board....So whats safe on a stock-bolton car without a WB??
POST MIRRORED at hptuners.com
Old Feb 14, 2007 | 05:23 PM
Billiumss's Avatar
1.15-1.18 if its mostly stock (stock untouched MAF) without using a WB 02
Old Feb 14, 2007 | 05:31 PM
Magnet's Avatar
yea the car has pretty much full boltons (no pulley) and also running more timing (no Kr) so i set it to 1.15 as redhardsupra said. MAF is stock BTW
Old Feb 22, 2007 | 07:00 PM
melchoir's Avatar
Mine's currently set to 1.29 across the board =/ Maybe I'll try dropping it to 1.15 and see how that goes.
Old Feb 22, 2007 | 07:04 PM
foff667's Avatar
LS1TECH Sponsor
14.7/1.29=11.39:1 commanded a/f ratio which is a pretty rich commanded...thats not to say its your actual though.
Old Feb 22, 2007 | 07:44 PM
melchoir's Avatar
I think we set it to 1.29 to be "safe". It's never been tested with a WB.
Old Feb 24, 2007 | 09:09 PM
yobabiesdaddy2001's Avatar
Old Feb 24, 2007 | 09:16 PM
chrisj6's Avatar
Its extremely hard to say "safe" with no WB. The more you mod your car, the more the AFR is going to be off. I am going with Len on the 12.5.
