why does timing retard
Old Feb 16, 2007 | 05:50 PM
yobabiesdaddy2001's Avatar
Default why does timing retard
after doing some logging of Map and RPM, IGN Adv, I noticed that as MAP (low pressure) dropped that ignition would retard very low 4.5 etc sometimes at the closing of the throttle.
Is that normal?
Old Feb 16, 2007 | 06:23 PM
brad8266's Avatar
You shouldnt have knock retard at all. You might need to add fuel in some areas.
Old Feb 16, 2007 | 06:25 PM
not knock retard. Just the timing drops when you get off of the gas
Old Feb 16, 2007 | 06:49 PM
Ironxcross's Avatar
the timing retards because it doesn't like you
Old Feb 16, 2007 | 06:59 PM
98TADRIVER's Avatar
i had the same prob with my LS1, i had 4* of KR, this was due to a knock sensor error- i mustve bumped a wire or something when i changed to a LS6 intake. so i went into hptuners and changed my max KR to 0* in certain areas so i dont have KR anymore! as long as u run 93 octane you should be ok
Old Feb 16, 2007 | 08:06 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
DFCO not only cuts fuel, but also retards timing when you are off the throttle.
Old Feb 16, 2007 | 08:28 PM
Yea it is also RETARDED like your momma!
Old Feb 17, 2007 | 07:13 PM
Rhino79's Avatar
It retards to help drop rpms.
Old Feb 17, 2007 | 09:45 PM
txhorns281's Avatar
sounds like a winner
