How long can i drive on this?
How long can i drive on my 224 224 114 cam with just Lt's and catted Y pretty much minor bolt ons.. How long can i drive it without a tune? Or should i not drive it?
You can drive on it if you can keep it running ok (should be ok). But, I would highly advise against giving it any more than 35% throttle until you get a tune. You're timing is going to be off and your AFR outside of closed-loop operation is going to be off even further. So, I wouldn't go flooring it for sure.
Dude you'll be fine as long as your not ******* it. Is it the completely stock tune now? You really dont have to worry too much about the timing, its the AFR I would worry about. I would say dont go above 70% or so.
