ltft tuning clarification with predator
Remember, lower injector flow rates mean a richer AFR and higher PE settings mean a richer mixture.
So, I'd try lowering the injector setting 7% and leaving PE at 0%. Drive around a while and see where your fuel trims are. After enough miles of various driving conditions (light/moderate/heavy) throttle, check where your LTFT's are. If they are 0% or less than 0%, move on to PE. I would guess you would need to reduce PE. But, it might not be the same % as what you do to the injectors.
If you're getting ltft readings of -7 at cruise, then you will need to adjust injector slope to +7%.
And modifiying the PE tables by 1% isn't going to do much. Do the injector slope change first then take another log and see where your ltft's are at and also the O2 voltage. Changing the injector slope will affect the WOT/PE as well.
After taking another log and seeing where you're at, then you can adjust the PE ranges - you want to be between .88x and .910. If you're lower than that, add to the PE ranges - I'd say +5%.
Do that and then drive around for a bit and take another log, I'll bet that'll have you right back in line.
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Idle fueling isn't too critical since the fuel trims are working to keep it in line. So, I wouldn't be discouraged if I saw LTFT's as low as -10% at idle. The key is while driving, you don't want more than +1~2% trims (again, as stated above). If you can increase the injector correction (ie pull it back to -5%) and still not see positive trims after a good bit of driving, then you should. If not, keep the injectors and finish PE.
"SHIFTING: When you look at these logs, monitor engine load. Engine load is a major determining factor in shift settings. If the change in inj. slope is causing an excessive rich condition (and the car is losing power as a result) it will change the load and thus the tranny will react/shift differently."
I have mine at -5% now and PE at +3 and this thing runs like a raped-ape now!
