Passenger side O2 sensor been unpluged for months!!
Old Mar 12, 2007 | 01:18 PM
GR33N GoblinM6's Avatar
Default Passenger side O2 sensor been unpluged for months!!
I was under the car 2 days ago.. fixing an exhaust leak... when i find that my passenger FRONT O2 sensor was unplugged?? i couldnt believe it, it must have happened when i disconnected it a long time ago and forgot to put it back on...
the strange thing is.. i never had a check engine light come on.. and the car didnt run rough.. i did notice a decrease in MPG.. by about 8mpg less than what i was used to...
but im finding it odd that it was disconnected and no check engine light ever came on... my light does work because it has come on for other things..
Should i be worried that something in the PCM is faulty?
i do have the EGR,AIR, and rear O2 deleted in the PCM.. would this make a difference at all?
Old Mar 12, 2007 | 01:36 PM
SSpdDmon's Avatar
It's possible the tuner killed the SES light for the front O2's - especially if you have long tube headers. They tend to trip codes for insufficient activity. I don't personally agree with turning them off. All it seems to do is keep them from having to explain to someone after a tune why their SES light is on. I'd rather know so I could fix the issue given the fact that the front O2's are responsible for closed loop fueling. In your case, you were probably running in open loop. If they tuned it right, your AFR should be pretty close...so I doubt you hurt anything. But before you go plugging that O2 back in, you might want to replace it. An O2 in the exhaust without power is damaging to that sensor. And if you're going to replace one, you should really replace the other so they read the same. Just my $0.02.
Old Mar 12, 2007 | 04:36 PM
Speed Inc. did the tune.. it was one of their mail order's.. they are pretty good tuners, so i have heard so i dont doubt them.. but its just odd..
Old Mar 13, 2007 | 02:27 AM
cantdrv65's Avatar
Post
If you didnt get a code then the MIL is disabled.....Its that simple.
Old Mar 13, 2007 | 10:54 AM
ok whats "the MIL"??
Old Mar 13, 2007 | 11:14 AM
2xLS1's Avatar
MIL = Malfunction Indicator Light, or Service Engine Soon light.
Old Mar 13, 2007 | 02:03 PM
oh nice... is that what they do when they delete the EGR AIR and rear O2's? i thought they were just supposed to make them not report... not disable the SES light.. WTF??
Old Mar 13, 2007 | 03:38 PM
2xLS1's Avatar
You usually have 4 choices with codes.
1. MIL on 1st error.
2. MIL on 2nd error.
3. No MIL. (stores code but does not turn on MIL)
4. No Error Reported.
For the AIR, EGR, and rear O2s you set all those codes to No Error Reported. That is the just how you turn those off. What it looks like in your case is that they maybe also set your front O2s to either #3 or #4. That's not a comon practice as you need those O2s working and need to know if they are not. The only way to know for sure is to have someone read the cal out of your PCM and see what they are set to.
Old Mar 13, 2007 | 03:48 PM
do you guys find it odd though.. that the car didnt stumble or run bad? I mean i did get less mpg but other than that, the thing acted normal..
i whish i knew someone with equipment to look at my PCM.. i dont know a soul in my area that has access to this..
Old Mar 13, 2007 | 04:54 PM
Billf6531's Avatar
Perhaps if you told the world where you are, someone would step up to the plate and assist you.
Old Mar 13, 2007 | 05:06 PM
i live in Utah... and finding someone with HP or EFI Live is few and far between.. i have asked on the western board.. as well as other places.. so far no one has stepped forward.. and there are not too many performance shops that are astute enough to deal with LS1 PCM's.. most around here are import tuners, like COBB tuning for Subaru's.. and others for mitsubishi's..
i guess i can take her down to CA since i am orignally from there..
on a side note.. i just ordered 2 bosch 13111's, just incase the O2 was bad.. might as well replace them both..
Old Mar 14, 2007 | 04:15 PM
i have a different question...
if i got a hold of a scanner/code reader... would it show any codes if there were any set, if the MIL was disabled?
Old Mar 14, 2007 | 11:10 PM
2xLS1's Avatar
If set to the option #3 I posted above, yes. #1 and #2 don't apply since you got no light. If set to #4, then no.
