DESPERATE! new head cam package will not start
Old Mar 25, 2007 | 11:29 AM
dazman's Avatar
Default DESPERATE! new head cam package will not start
got my car back together... 97 corvette
ms4
prc heads
underdrive
ls6 intake
headers
car cranked GREAT first time and idled great, ran it to the top of the road. idled great, but when i got it back to the house it would not find idle and just kind of ran crappy - missing, puking, bucking ... but now will not do anything. it is deader the hell and throwing p1571 p0171 p0174 will not even start
please help!!!!
Old Mar 25, 2007 | 12:19 PM
See5's Avatar
http://www.gearchatter.com/viewforum...days=0&start=0
Clear codes and try again.
Old Mar 25, 2007 | 01:25 PM
Billiumss's Avatar
Did you tune it or is this on a stock tune?
If on stock tune, you have to get the car tuned for the new mods.
Old Mar 25, 2007 | 03:31 PM
jimmyblue's Avatar
Moderator
What's funny is the initial start working. Kind of says the
original state of tune was kind of OK but it's (mis)learned
something - like idle trims, fuel trims etc. Though start
should be open loop regardless. The gross lean codes say
either the O2 sensors are left unhooked or bugger cold and
this would for sure whack closed loop (+25 LTFTs before
this code sets) and who knows, maybe corrupt startup
fueling?
Old Mar 25, 2007 | 08:03 PM
dazman's Avatar
fueling?
car is tuned by texas speed... i got their all inclusive package.
now the car will not even start.... only code is p1571 h c
Old Mar 25, 2007 | 08:05 PM
dazman's Avatar
Originally Posted by See5
i can clear the codes all day long and it will still do the same thing... only code that it is throwing now is p1571
Old Mar 25, 2007 | 08:26 PM
jimmyblue's Avatar
Moderator
Nothing going on with the security light etc. is there? Can you
verify fuel pressure and presence of spark (even if not right, at
least showing up)?
Old Mar 25, 2007 | 09:55 PM
Doc's Avatar
Doc
Sounds like a huge vacuum leak to me. So, just to be clear, you bought the heads, cam, associated hdw and a tuned pcm for your 97 vette from TSP? All things considered TSP is a good crew, a vacuum leak would play this kind of havoc. Do you still have the stock PCV system or did you upgrade to the LS6 style? Catch can, breathers...details. "Works" fine-what kind of idle are we talking about 1k+ after a proper warm up? That's not good. So you drive down the road and your Fuel Trims are going crazy and set the codes. Some sort of leak, weather exhaust or vacuum.
Old Mar 25, 2007 | 09:58 PM
brad8266's Avatar
Originally Posted by Doc
Sounds like a huge vacuum leak to me. .
i posted that same idea in his other thread in internal forum. With each bank throwing a lean code there has to be a huge vacuum leak.
Old Mar 25, 2007 | 10:05 PM
dazman's Avatar
least showing up)?
yeah, my security light has been on for two years. you think it could be from that?
Old Mar 25, 2007 | 10:08 PM
dazman's Avatar
i bought heads/cam/headers/clutch/tune all from tsp. i bought ls6 intake/oilpump from thunder racing. this will sound really stupid to yall but i dont know what a pvc is. no catch cans or breathers... the only code that is being consistently thrown is the p1571 h c ...... the lean codes come in after i drove it a while.
Old Mar 25, 2007 | 10:36 PM
Doc's Avatar
Doc
Dude, I hope you won't take this the wrong way but I can't help but think what an amazing time we live in where this firehose of information exists that makes us feel comfortable about diving into our motors yet, at the same time shawdos the simplest of truths.
The PCV system is the Positive CrankCase Ventilation system. In a nutshell, your motor is made up of 3 main chambers, main block and the two respective heads. I guess you could add the intake too. The PCV system of hoses and a valve "equalizes" these zones relative pressures so to speak in the most elementary of explanations. A leak in this system(s) will add unfiltered, unmetered air to your engine. A stock, non calibrated pcm might.../I have personally witnessed will "idle" @ around 15k+. It will surge like an old *****. Smaller but equally frustrating leaks will fool you/ your tuner into thinking that the car wants "...this..." until these issues are resolved you will chase your tail in perpeptude.
Given your situation where you have a packaged tune setup for the physical package you bought, this only reinforces this logic path of the grande and not so sexy leak you are fighting.
Next question, did you use a calibrated torque wrench with the factory aprroved pattern on the intake? New intake manifold gaskets?
Old Mar 25, 2007 | 10:50 PM
dazman's Avatar
oh well i knew that there was vetilation for the motor, just never really had to deal with it... intake was brand new as well as the gaskets. but was taken off and put on about 7 times due to a head issue.
