How to dial in timing?
Old Apr 6, 2007 | 02:16 AM
fil131's Avatar
Exclamation How to dial in timing?
I am using Ls1-Edit, and have Knock retard showing at WOT.
How do I dial in my WOT timing to get rid of the knock through the use of tuning?
Thanks in advance.
Fil131
Old Apr 6, 2007 | 06:45 AM
brad8266's Avatar
First thing, what are your mods?
Smooth out the timing tables first, I had a thread yesterday about smoothing the timing table. read this https://ls1tech.com/forums/pcm-diagnostics-tuning/690175-timing-table-looks-like-shit.html
Before you make the assumption that it is surely a timing issue I would ensure that everything else in ok such as plugs, wires, and fueling. How does your AFR look at WOT as well?
How much KR are you getting anyway? One way you could do it is to bump down the entire table by 1 degree at a time, but if the table is stock than there should be no need to decrease timing.
Old Apr 6, 2007 | 01:04 PM
fil131's Avatar
All I have is a K&N fipk, new plugs and wires.
I'm just trying to tune for performance and driveability right now.
I do not have any dyno time or a wideband yet, and have been solely tuning with fuel trims using injector flow and Maf tables.
I have a few scans and excel sheets I can send you. that I got with LS1-Scan.
Thanks for your help.
Fil131
Old Apr 6, 2007 | 01:08 PM
fil131's Avatar
Also I've seen as high as 45 on the scan for KR. Let me know if you want me to send you some of the data.
brad8266's Avatar
Fil131
Do not tune using IFR that is the wrong way to tune. Tune LTFT's via VE and MAF only. The IFR should refect your fuel injectors, tuning with IFR is some half *** ****.
A stock car should be 100% drivable already.
Old Apr 6, 2007 | 01:09 PM
brad8266's Avatar
Where did you see 45 of knock at? Were you in high gear?
Old Apr 6, 2007 | 01:13 PM
Doc's Avatar
Doc
Let's do the time warp again....No wideband, LTFTs, LS1Edit, IFR shinanagans, sheesh! Do you drive with the headlights off down dark roads?
Old Apr 6, 2007 | 01:14 PM
brad8266's Avatar
IFR shinanagans
Old Apr 6, 2007 | 01:21 PM
fil131's Avatar
Default Is it my timing?
third gear
Old Apr 6, 2007 | 01:24 PM
brad8266's Avatar
third gear
Are you geting 45 of knock retard or 45 of spark advance? They are 2 different things.
I suggest you reflash a stock tune since you messed with stuff that should have been left alone.
Old Apr 6, 2007 | 01:39 PM
fil131's Avatar
When I put the stock tune in I run VERY VERY rich, lots of black smoke in idle.
With upping the injectors a bit and and leaning out the maf table everything under WOT is great.
***I also forgot to mention that I have an 85MM Maf sensor too.***
fil131's Avatar
and its 45 KR
Old Apr 6, 2007 | 01:48 PM
brad8266's Avatar
and its 45 KR
Your **** is fucked up. Put a stock MAF back on too, the aftermarket MAF's suck. Also reflash a stock tune. The only way you are running that rich at idle is if your O2 sensors are not working. You are just doing half *** bandaid fixes to cover up.
Old Apr 6, 2007 | 01:57 PM
fil131's Avatar
I put the stock maf and tune in as well and it still runs rich, I wouldnt be here asking about timing if I hadn't already tried to revert back to stock.
I can send any of you my excel scans and LS1-Edit pcm tune just let me know.
Old Apr 6, 2007 | 01:59 PM
brad8266's Avatar
send me your .ls1 file. brado8266@yahoo.com
Old Apr 6, 2007 | 02:03 PM
fil131's Avatar
email sent
Old Apr 6, 2007 | 02:37 PM
Doc's Avatar
Doc
Which aftermarket MAF? If you are going to keep MAF operation don't chuck that sucker just yet. You can remove the "Xtra" component that will be painfully obvious and still rescale the MAF's cal. But unfortuneatly, only with a WB02. For ~200 bucks you will have an invaluable "flashlight."
Old Apr 6, 2007 | 03:21 PM
fil131's Avatar
I have the granatelli 85mm Maf sensor screened. My idle and part throttle are great, I am going to get a Wideband, I just havent got to that yet.
I really dont have any real mods on the car yet so havent yet put out the dough.
Old Apr 6, 2007 | 04:27 PM
brad8266's Avatar
Ill have the file back by moday at the latest, i will be at rockingham today and tommorow at the pinks event so i may or may not get to it until after then.
Old Apr 7, 2007 | 01:45 AM
fil131's Avatar
that will be great, thanks for the help
