Help: KR when starting from a stop!
TIA
https://ls1tech.com/forums/showpost....1&postcount=10
I can get up to the max 15* as well in this same scenario, all in the same MAP RPM range. Putting in poly motor and tranny mounts to see if this helps.
Race gas is the next step, as I have pulled timing in the range and pumped fuel at it with no improvement.
when I go back home to the Dakotas, and sit around the family table, the "oh ya"'s get pretty thick.
Ya sure youbetcha donchaknow
Here in the desert you better have shorts and a jacket with you at all times. In the last 3 days it's been in the mid 90s(warm), in the low 30s & snowing and today was high 70s(PERFECT).
Good luck with your knock issue....
SSpdDmon
Assuming the knock is false would I be correct in assuming {B6214} Adaptive spark min rpm is what you would want to change? Like raise it from 300rpms to lets say 1500????
off.
