Help: KR when starting from a stop!
Next stop, race gas and pullin the valve covers to check for issues.
Any other ideas where this could come from?
I was just running a tune with advance hovering in the upper to mid teens in the trouble areas so I like to think its not a spark issue.
I'm just worried there's something SERIOUSLY wrong with my build causing this and I'm not sure where to start.
Clutch chatter. I can hear it quite well. I have always assumed it was that. My car did it from stops and when performing any 1->3 or 1->4 shift.
Another question; what should AFR (O2s and ratio please) and airflow be at idle durring cold starts or when at op temp? Smells way rich?
see the O2s bottoming instantly and then switching but no
switching at all and stuck rich at idle with constant STFT
creep. It's trying to fix itself but never seems to get there
and every time you pop between cells, you start over from
zero (which is evidently not the right answer).
I'd concentrate on the low RPM, airflow and fueling end of it
and see if the spark situation fixes itself.
OK so I got the WBO2 in. Seams it is indeed going flat lean on leaving from a light. Also, car seams to run better with the AC on so I will have to compare tables there too. Any ideas on how to get this thing to have more fuel from a stop? So I think once I get the fuel inline, I can give it more timing down low as it seams weaker now than before and I feel I removed too much timing.
