'02 pcm in a '99?
Old Jun 14, 2007 | 01:57 PM
Mia's Avatar
Mia
Default '02 pcm in a '99?
can it be done? any advantages?
Old Jun 14, 2007 | 02:22 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Wow, there's a thread right below yours with the exact same question:
https://ls1tech.com/forums/pcm-diagnostics-tuning/731373-swap-not-swap-98pcm-99-a.html
Old Jun 14, 2007 | 02:23 PM
SSpdDmon's Avatar
It should be fine. You just need to have the '99 calibration flashed into the '02 PCM.
Old Jun 14, 2007 | 02:29 PM
Mia's Avatar
Mia
I was thinking of sending in a pcm to get tuned, I have access to a '02. I didn't know if it would work
Old Jun 14, 2007 | 02:33 PM
ls1CANTU's Avatar
I'm running a 2002 pcm in my 99 trans am and it works like a champ. all i did was run off of my frends 02 trans am file and then i just tuned pcm and did the crank relearn and works awesome.
Old Jun 14, 2007 | 03:20 PM
Eurospec2's Avatar
Default pcm
they are the same PCM
Old Jun 14, 2007 | 03:23 PM
SSpdDmon's Avatar
Correct. But the operating system and calibrations are different. If you have a stock '99 and throw in a stock '02 PCM with a stock '02 tune, it'll run. But, it won't run as well. Take for example the timing map - on the '99 it's way different.
Old Jun 14, 2007 | 03:26 PM
Eurospec2's Avatar
https://ls1tech.com/forums/showthread.php?t=731373
Putting a 02 comp into a 99 is plug and play, the other thread is about an 02 comp into a 98 which is a whole nother ballgame
Old Jun 14, 2007 | 03:29 PM
Mia's Avatar
Mia
ok so basically they are the same pcms with different part numbers. what changes is the
operating system and calibrations? so if if get my hands on a 99-02 and changed the settings to work with my vehicle, I will have no issues? what I am trying to do is avoid down time on my car
Old Jun 14, 2007 | 03:41 PM
SSpdDmon's Avatar
What's wrong with your PCM now?
Old Jun 14, 2007 | 04:02 PM
LS1curious's Avatar
Do not flash a 00-03 cal into a 99 pcm. the adress offsets are a wee bit different.
However a 02 pcm is a drop in using o2 code.
Old Jun 14, 2007 | 05:27 PM
SSpdDmon's Avatar
2 questions?
Why not? There are people running '02 OS's in '99 and '00 cars without trouble as far as I know.
My friend's '99 had the same factory OS as my other friend's '00, just minor differences in the calibrations. Why isn't this a problem?
We're both talking a full flash here, right? Not just cal's...
Old Jun 14, 2007 | 05:48 PM
Mia's Avatar
Mia
nothing. I can't get my hands on a '99 pcm but I can on the other. I don't want to send the pcm out of the car have and have the car immobile
Old Jun 14, 2007 | 06:20 PM
Doc's Avatar
Doc
What modifications do you currently have? Your Crank Position data will be different than the "new" 02 pcm's. You may or may not set a code for it-which you'll have to have someone perfrom a CPRelearn. Your VIN data will also not match up. Your best hope for no problems would be if the "new" 02 pcm has the same trans, hardtop/VERT, F or Y body as your original. You still stand a strong chance of running into the CPR problem. Some of the big sponsors now have little boxes that they can ship out to you so you can reflash a new Operating system and calibration rather than you having to send in your pcm and effectively down your car. I hope that is what you are trying to get at.
