Need some help w/ SD tuning on 402/F1R!!!
I am trying to get my motor tuned. I got the idle down pretty good, but I can't get it to rev up in neutral. I look at my wideband and it sells me that I am running really lean. So I use my HPT in RTT and bump up the VE table. I get to a point that the fuel looks ok, but the motor still stumbles on throttle movements. I have more than enough fuel available (96-lb/hr) and my fuel pressure is a steady 40psi. I REALLY would like to see if someone can let my use their tune to help me atleast get a base line. Or if there are suggestions, I am all ears for that too.
BTW, I did do a MAF tune with the stock LS6 intake with 37# injectors and it went very smooth
You say fuel pressure is "steady at 40 psi" so I'm assuming that means you're not using a boost referenced fuel pressure regulator. What does your Injector flow rate table look like?
Those are big injectors. What brand are they?
The injectors are Delphi. I bought them the same time I got my Versafueler.
Like I said before, according to my wideband O2, the car goes lean when I try to rev the motor.
OK, I got it running alittle better, now I have a new issue. My gauge reading on the scanners matches what my Autometer is showing, but the Table are off between 25-30kPa. Even the LTFT histogram and chart displays are off by the same amount. Also with WOT @ 6000 the gauge says 185kPa and all the others are saying 100kPa. What has happened?
LS1TECH Sponsor
Originally Posted by Gold Phoenix
OK, I noticed that and removed it from the table. However, I am still see the same thing.
If you want to try a quick fix, delete your vcm scanner.cfg file. This will reset any custom PID's that might be referencing map when they shouldn't be.
LS1TECH Sponsor
your maf fail freq. was fine....i mean in the end all you really need to do is unplug your maf sensor to enter SD, but by setting the errors the way you did it tells the computer "yeah everything is fine even though the maf fail frequency is 0" meaning you won't fall into SD mode. Setting them to no mil is the way to go.
