Anyone use a Wait4me Mail order tune?
As far as Cams ect and other tuning. It is all Math and the tunes should all be extreamly close to being perfect after the tunes. UNLESS there is something wrong or not working correctly on the vehicle.
I use Fuel sampling different than stock and timing and airflow correction all Automatically when people get my tunes. So the tunes should and do just fix themselves. This works perfectly as long as there are no air leaks, bad/warn out sensors, or bad parts on the cars. 95% of the time when someone has a problem, it is always due to a problem somewhere on the car. Not the pcm calibration.
Sure if you would take the car somewhere they can make it better if in person, That is because they can compensate for the flaws that are being shown from the bad sensor or other issue on your car.
From doing dyno tunes and tunes in person all the time, I would say 1 out of 20 peoples cars are perfect condition when they get to me and are ready to be tuned. The other 19 would have something that needs to be fixed or troubleshooted in order to make the car run right. From bad sensors to missing parts... Just fixing those little things makes a huge difference in the running of a vehicle.
Another thing that i would like to say is, Out of 18,500 tuned pcms that we have set up and sold, we are bound to have a few that are not happy, that is just life. I maybe only know of 20 ever. That isnt bad for the amount of happy 18,480 people. We also give free updates on any tuned pcm we sell you guys for life... So im not even sure why those 20 people would have room to complain, as im always a phone call away and can always figure out what the cause is and modify them to suit there needs...
$159 including a tuned stock pcm and no core and free updates for life....
There is no magic thing that is going to make any tune better than another, it is just how the tuner can set up the controller to fix itself better. Timing is timing and fuel is fuel as it was in carb engines as it is in FI we just have alot more control........
I usually dont post to defend myself, but for some reason the invalid part with the Vin numbers is just above and beyond on what is not true.....
I emailed you my mods and my car is bone stock right now with only 10k miles in perfect running order so it should be a great project car.
Please let me know so we can start the ball rolling, I'm sure you want money up front which is fine by me, I just need to hear back for confirmation of leadtimes and my mods.
Thanks,
Tim Sheets
[edit: your email reply arrived just as I hit the submit button]
I've had perfect sensor readings all over the vehicle that will affect the tune, no lazy O2's, screwey MAF's, MAP's, TPS etc etc... everything looks to be working just fine when I hook it up to HPT... you seem very quick to point the finger at bad parts when something doesnt work like you intended When I'd venture to say the majority of cars on this site are pretty well taken care of... they may be driven hard (as they should be) but I believe most do the right work to ensure they stay that way...
I'm not bashing or trying to start a pissing match but, some of what you say is incorrect.
On a factory pcm with a factory type os, yes, the tune would be limited.
I however give the pcm full range to fix itself. It knows how to monitor spark differently and make an on the fly changing spark set based off of feedback and frequency patterns from knock sensors.. That is why the spark tables dont act the same and are always different if someone logs it. It will fix spark at idle to make the smoothest idle, it changes and will max itself out during light cruising, and it will change it even at wot to make the most calculated torque..
Same goes for airflow. The tune will set itself up and add or subtract airflow to make the smoothest idle. It has infinate control as long as it it mechanically possible and will add or subtract airflow in conjunction with the spark control to make even super huge cams idle smoothly.
Same goes for Fuel correction. My tunes will use o2 feedback even at wot to see the amount of error the o2 sensors themselves are and change all my settings to make them more correct and apply that to the final fueling.
Im sure other shop owners will agree on what i say on the amount of things they have to fix when the cars come to thier shops....
Which widebands do you recommend for permanent install? That sounds like it may be worth the $. How much better will the car be able to adjust especially for me where I may drive around my house at 4,800ft above sea level, up and over mountain passes that are nealy 9,000ft and then down to sea level within 50 miles. Pretty diverse pressure changes.
My car is not a DD and it usually just stays at the 4,800ft altitude, but if I may take it for a weekend cruise like mentioned above. I was planning on just mixing some race fuel or octane booster to be safe at lower altitudes.
now i've got a MS3, it fires up and idles great. it's very rich, but from what i've seen, that's impressive.
only thing i was a bit miffed about is the rev limiter wasn't changed to where i wanted it. i know he'd fix it in a heartbeat if i sent it back in.
Any phone conversation related to looking into what I'd already been taking apart and replacing with different parts to rule out as issues. So I gave up, opened the throttle body blade up, and enjoyed the watery eyeballs while listening to the sweet cam lope.
I would recommend the tuning for a header swap/tuning out sensors and such for certain worth the money. Just no results on shift points, line pressure, or idle. Never got to take the car for dyno tuning to see if my PCM did the same thing as Ego's with the VIN number issue.
I have to say that at the moment, I am pleased.. I didn't expect it to be perfect and am still planning on putting it on a dyno and fine tuning it, but for what I needed Jesse to do, he did..
It is running fine.. I could easily leave it like it is and be completely happy with it, however it is running pretty rich and I don't want to leave it like it is, so the local LS1 guy is going to tweak it for me..
I can report back with what the differences are...
I plan on doing a dyno run with Jesse's tune and then a couple after the local guys tune and we'll see...
Today I talked to Jesse to see what he thought might be the problem and what I should do? He suspected a vacuum leak and I understand the logic, but don't think that vacuum is the problem. The motor runs to smooth and consistent on the sotck PCM, but trouble shooting over the phone is not easy.
So tonight I bumped the throttle body idle stop up a bit just to where it was holding the motor at about 970rpm. Then I swapped the Wait4me PCM. All be dammed if it doesn't also run great. It runs better at off idle and low rpms under load. WOT seems the same, but it was awesome before. Idle now is the oppisite. Now on hot restart it runs up to 1,300rpm for 10-20 seconds and then settles back in to about 940rpm. My nose tells me it's not as rich while cruising or idling also.
I don't know why it didn't run right the first try, the only thing changed is the butterfly stop on the TB. The throttle response is definitely better with the new PCM. I can't wait to drive it a little more.
[Edit] Drove it a little more and it definetly runs better with Jesse's PCM. Like I said, WOT is hard to tell, but low rpm high loads it drives much better. It still idles up when you come to a stop and when you hot start it. For about 10-20 seconds it will idle up to 1200-1300rpm and then settle down. I'm going to back the TB stop down a little bit and see if it helps. I think I may have increased it just a little too much. Motor runs very crisp and strong from 1200rpm to rev limit. Of course it likes to be jumped on at above 3000rpm, but it pulls good while cruising at low rpm too.
My car does not look modded and thanks to a good tune it doesn't drive like it's modded...it just has more power.
The only thing that looks non-stock is the long tubes on it.
