i think its a tuning issue
Old Aug 12, 2007 | 02:27 AM
CASHss99's Avatar
Default i think its a tuning issue
new trans and rear, when i come off a light ill roll then lay into the gas not mashing it down but laying into it and the car sounds like its going 100 but goin like 35mph.. i have no idea
Old Aug 12, 2007 | 12:39 PM
VinceTrifecta's Avatar
Major transmission slippage?
Old Aug 12, 2007 | 12:48 PM
CASHss99's Avatar
i wouldnt think so its a rebuilt 800hp trans
Old Aug 12, 2007 | 12:52 PM
Nice car, btw.
When you say "sounds like its going 100..." do you mean the engine is revving up a lot, but the car isn't accelerating?
Old Aug 12, 2007 | 01:07 PM
CASHss99's Avatar
like its climbing the rpms but not bouncing off the limiter at all and not moving
Old Aug 12, 2007 | 01:08 PM
CASHss99's Avatar
when im driving it and get on it at a light it feels like im spinning the tires but my friends say that im not
Old Aug 12, 2007 | 01:12 PM
Well, a higher stall torque converter will do that - lets the engine rev up higher then stock (in the case of PT4400, I'm assuming 4400 RPM) before transmitting the power to the transmission. Below the "stall RPM", this would give the feel of major slippage.
Old Aug 12, 2007 | 01:27 PM
01Z28M6's Avatar
I would think a 4400 stall would barely be street-able. I don't really know but a stall that high sounds radical; something for a dedicated drag car. I have a feeling I'll find out.
Old Aug 12, 2007 | 03:37 PM
edcmat-l1's Avatar
Even with a 4400 converter, it shouldnt feel like its "not going anywhere". It'll slip, but it should make the car go.
Even a stall that hi, wont slip all the way to 4400, thats actually the "flash" speed. Depending on the quality of the converter, it could feel just a little looser than a stock converter, without putting it against a brake.
If you can get it to rev at all above the stall speed, without it spinning the tires or moving the car, theres definitely something wrong.
Old Aug 12, 2007 | 05:11 PM
Frost's Avatar
I've tuned a half dozen cars with that PT4400, it's a power adder stall so it's tight even under flash in every car I've ridden in. If it feels loose now, somehting isn't right.
Old Aug 12, 2007 | 06:12 PM
CASHss99's Avatar
it shifts into 2nd to fast and 2nd drags way to far when i drive in D...
