Please Help me, LEAN condition!
If one of the voltage's on my B1 Oxy sensor is stuck at a constant 450mV does that mean its dead, and would be a good cause for the lean condition??
All intake bolts are tightened down, call connectors connected, and all vacuum lines are hooked up.
I have an OBDII data streaming gauge to watch voltage and fuel trims, and I look at a narrowband just for a overall look(i know its not exact). The narrow band is connected to the blue PCM wire. Is there a possibility that the narrow band is hooked up to the bad Oxygen sensor?
Please help me!
Just inspect the wire harness leading to the O2 sensor for damage from header heat or some other means. You can try swapping O2 sensors also to see if the problem follows the sensor.
There is nothing wrong with anything, and the ****** things dont wanna work....pisses me off.
