383 lt1 probs.
Old 09-19-2007, 01:29 AM
pyronotic138's Avatar
Default 383 lt1 probs.
383 car ran great and then one day just felt doggy as hell and a stocker can keep up with it. used to run 11s. what sensors should i check. i have tried the MAF, MAP. what other sensors could deal with this.
Old 09-22-2007, 11:08 PM
anyone have advice
Old 09-23-2007, 12:33 AM
2xLS1's Avatar
Other than its a 383 LT1, you tell nothing about the car or it's mods. Has it been tuned? Have you done the basic checks? Pull the plugs and look at them? Check the fuel pressure? Run a compression check? You need some kind of scanner to see what is going on. Anything else is just a guess.
Old 09-23-2007, 01:40 AM
383, stock intake. minor ported polished heads, cc306 cam. yes it was tuned. my friend had it and it ran like a ****** ******. then my other friend got it and over a couple days the car just went downhill. new plugs. msd 8.5 wires.
Old 09-25-2007, 02:02 AM
anyone please help with a fbody owner. hehe. if you own one which you shuld if you on here then you know what a hassle they are lol
Old 09-25-2007, 07:39 AM
moehorsepower's Avatar
Well like 2Xls1 says, we need more details, runs like **** does not tell us anything, Please be more accurate and maybe can chime in and help....
Old 09-26-2007, 11:38 PM
accurate about what. the car doesnt get up and go worth of dogshit anymore. a stock lt1 can keep up with it. it used to be an 11 second car. its just a 383 lt1 with ported heads. cc306 cam. stock intake, mac mids, 1.6 RR. 373 gears, 700r4 trans. one day the car just decided to not have horse. i checked the MAF, MAP.
Old 09-27-2007, 12:04 AM
2xLS1's Avatar
You havent even said what year it is. We don't know if it is OBD1 or OBD2. A LT1 could be either. You need a scanner and datalog it. What do you mean you checked the MAF and MAP? How did you check them? You need a scanner and datalog it. How is anyone here supposed to know what is wrong with it without seeing some data? You need a scanner and datalog it? Did you run a compression check? What do the cylinders read? Have you hooked up a fuel pressure tester to the fuel rail? What is the fuel pressure? Did I mention you need a scanner and datalog it. Post some data and I might be able to help.
Old 09-27-2007, 12:09 AM
kinglt-1's Avatar
we cant pull answers out our asses!! Need more info lol.
Old 09-27-2007, 03:52 PM
obd 94 z28 by chekcing i am saying we replaced them. sorry. i didnt know the sensors would make **** difference on obd1 or obd2. i have no clue what to look for on logging it. i should say i see numbers but dont know wtf they mean.
Old 09-27-2007, 09:47 PM
Stroked96Bowtie's Avatar
Old 09-28-2007, 12:30 AM
uh k
anyone have any idea what it could be. obviously a sensor issue i would hope. for the fact it worked great one night and then the next day it didnt. electronic BS goes out and on these can instantly cause a prob. anyone know what i should look for first.
please be seroius
Old 09-28-2007, 07:31 AM
aknovaman's Avatar
Do you have a datalogging cable and datamaster software? If so, send me a datalog and I can look at it. If you really do not know what you are looking at, PM me and we can discuss. If not, where are you located? If it's close to KC, I can help.
Old 09-28-2007, 08:16 AM
Mikes96z's Avatar
Like everyone said, you need to scan it and monitor engine operations. My guess would be with your injectors, but I don't know what you have. It could be a vacuum leak, does i idle ok? Engine codes? If something is bad enough the PCM will go to LIMP mode. No power there......
Old 09-28-2007, 01:53 PM
we checked vacuum. i have datamaster. do i just have to record the session or what. and what else you want me to do on it.
Old 09-28-2007, 01:54 PM
i was told to check the knock sensor also. it may have an affect on it?
Old 09-28-2007, 01:59 PM
aknovaman's Avatar
You are shot gunning the problem.
Old 09-28-2007, 07:48 PM
wlel how do i do the datalogging ****. i will do it and send it out to whoever wants to look at it. i need to know what to do though. thanks everyone
Old 09-28-2007, 07:49 PM
edcmat-l1's Avatar
Originally Posted by pyronotic138
uh k
anyone have any idea what it could be. please be seroius
Could be:
1-high exhaust back pressure
2-low fuel pressure
3-opti problems
4-other secondary ignition problems
5-tune problem, LTFT off now after a couple days of trending
6-wiring issues
7-various sensor issues, ie, coolant, iat, knock, etc
Man, I could go on and on. If you dont know what you're looking for, take it to somebody that does. And I am being serious.
Old 09-28-2007, 07:58 PM
aknovaman's Avatar
PM me your phone # so I can call and discuss.
Anthony
