car hits 4600rpm and POW, backfire and shuts off???
#62
What happens if you get on it pretty good and it has'nt back fired, and you shift hard into second? Mine sounds like the fourth of july!
I have also noticed with mine, that if I smash into the gas (say first gear) at about 5000 RPM it just shuts off, now that my car is off, then it decides to back fire a few times. Is any of this similar to you?
I have tried the unplugging my MAF and it still did it.
#63
I wonder if you have a sticking (ie leaking) fuel injector. Thats so wierd that it backfires after the car has shut off.
We have tried, CKP relearn, new PCM and MAF unplug right?
#64
I think you are correct in the order that this happens. Its like it cuts out and falls on its face, shuts off and as your coasting down the road, thats when it will backfires.
Mine does this in every gear so once it does this, I have no chance of shifting into the next gear.
Im going to replace the ASP pulley for a stock one. My buddys ASP got messed up and was giving his a **** load of missfires. Although, I dont think his did want mine is doing.
Im going to unplug the MAF and try it and I also want to replace the entire wire harness.
#65
hhmm, its weird your car ran differently, yet still bad, with the other pcm... if you have a friend that really trusts you would it be possible to swap your pcm into his car, and see if his car does the same thing yours does, that would clear up if its related to YOUR pcm or something else...
#66
#67
I will try to make a video this weekend, I feel like I am hurting my car when I do it but, I checked my new plugs I put in after this started and they didint tell/show me anything. They werent white like yours, I remember the ones before those, had a redish tent to them, what does that meen?(?? Lean and hot ??) My car smells really rich??
Hey KCFormula want to try my pcm, your car isnt anything specail anyway! HaHaHaHa
#70
Just looked at a stock '99 TA tune and it does have the 6101 table, the related code 1514 is set as 'Not Reported'. Put my C5 into limp mode till car was shut off and 6101 was adjusted. Maybe Paul has a point.
#74
heres what I left to try.
unplug the MAF
swap my ASP pulley for a stock pulley
new wire harness
possibly swap my PCM into my buddies car to see if his car acts up.
pull motor and check reluctor wheel even though i had my finger on it trying to move it around and it would not move at all.
#75
[QUOTE=CompCamaro;8045154]I will try to make a video this weekend, I feel like I am hurting my car when I do it but, I checked my new plugs I put in after this started and they didint tell/show me anything. They werent white like yours, I remember the ones before those, had a redish tent to them, what does that meen?(?? Lean and hot ??) My car smells really rich??
I have seen redish spark plugs once when someone was using octane booster.
#76
Yea I looked that up also on Holden Crazy Tune file,I thought so.He should add that to things he has left to try...................Paul
#77
well, I swapped my PCM (6 speed) into my buddys camaro (auto) and for some reason his car would hit 2500-2600 and it could not rev any higher. the only way I could explain it was like hitting a rev limiter. Mind you guys, his PCM was in my car and I didnt have this problem.
#79
Well, I disconnected the MAF....no good. Still did the same problem.
Something to think about. If I gently ease into the throttle, surprisingly I can rev it to 5000-5500, then I just let off. But if I stab the throttle hard, 3000 or so, the car just starts breaking up.
about 50% of the time the car will just break up extremely bad, and not backfire and shut down.
#80
What do we know about extreme throttle transitions ? The car reads the MAF almost exclusively when the throttle changes drastically. During normal smooth throttle operation it is a blend of VE, MAF and a lot of other stuff.
It may be possible that the issue lies in the MAF table. Just a thought - my car ran like *** until I tuned my MAF table with some help from Rick at Synergy (who is "the man", BTW).
If you compare your friend's MAF table to yours, are they different ? Do you have a way to scan/log the car ?
Edit : hmm, looks like it's doing it with the MAF unplugged so I guess that may not be it... However, getting different results with your friend's tune and his car having problems with your PCM/tune kind of points in that direction... It's also still possible you fried something in your PCM when you were soldering the wires, right ?
Rob (Bad30th)
