Upgraded to HPtuners MPVI Pro - having LC-1 issues
Background story is a I used to have the serial version of HPtuners and used it with success in conjunction with my LC-1 wideband.
Now, I have just upgraded to the MPVI Pro setup. I am having a problem with getting HPtuners to read the correct a/f ratio. I am getting a/f ratios consistently around 16-16.5:1. Now, I did not change any of the setttings in HPtuners, but I went back and checked them anyway. Everything in the scanner was correct. So, I figure it is the LC-1 acting up. I reprogrammed the LC-1, updated the firmware, and even borrowed a different O2 sensor from a friend. Still the same problem.
So, either HPtuners is messed up or the LC-1 is. So I get my trust voltmeter out and investigate. After everything is warmed up, the voltage coming out of the LC-1 is ~3.0 V. My LC-1 is set to read a/f ratios between 10 and 18 on a 0-5V scale. So, a reading of 3.0V at idle is right about where it should be.
Next I hook up the voltmeter to the wires I have running into the cabin. They are reporting the same 3.0V. So, the correct signal is being sent to the EIO. Now, I hook everything up and read the voltage at the EIO. It is reading 3.8-3.9 V
Can anybody help me understand what is going on? I seems I have a voltage offset, but this offset seems massive. I have heard of 0.1 offsets, but not almost 1 V.
Also, this setup is not different at all from before the MPVI upgrade. Before the upgrade I had no voltage offset issue at all.
Moderator
First off try looking at the raw voltage of all 4 inputs.
One (not sure which) is the "canned" LM-1 / LC-1 and
the others, if you connect to them, won't work with
the LC-1 selected PID. This isn't especially clear in the
docs but you can probably drill down to it.
Then, just for yucks, put your voltmeter beween the
MPVI-Pro ground screw and the LC-1 ground lead
with them not hooked to each other but operating
normally, independently. The ground difference you
see, may be small or not; if not, you want to tighten
that up.
that up.
Jimmy, thanks for your input. I checked the EIO inputs 1-4 and it got some weird results. When I first checked them all I would get about 2.5 V for all 4. But, after going back a second time and checking them I got about 15 mV on all of them
I am not sure what this means.
I also checked the EIO ground compared to the LC-1 ground as you suggested and saw ~25 mV difference.
Is it possible I have something wrong with my EIO?
Yep, recalibrated the LC-1. Also checked the settings on it several times. This time the the problem does not lie with the LC-1. How do I know? Well, I hooked my voltmeter up to the leads of the LC-1 outputs (without being plugged into the EIO) and the LC-1 outputs the voltages it is supposed to. My LC-1 is working perfectly. The problem lies in HPtuners EIO some where.
I would post this up on the hptuners forum, but for some reason my account wont allow me to post anything at the moment.
The HPTuners scanner needs to be configured to read the voltages correctly. Cant remember how to do it, let me see if I can find the thread.
http://www.hptuners.com/forum/showthread.php?t=5059
http://www.hptuners.com/forum/showthread.php?t=11018
