Anyone using LS1Edit on a Laptop with XP??
Thank you.
Good luck!
If you are using a USB -> Serial adapter it is going to be hit or miss which one works for you - if you are using the serial port and have a problem then you have an install/configuration issue.
For the guys who has XP and found a USB that works with them please tell me what brand and if u can give me the product number. Thank you.
I KNOW that others have had success with some versions of XP and Edit, but on my setup, XP Professional and Edit "mysteriously" stopped functioning.
I feel that it's my duty to report this to respective users of XP Pro and Edit. I've never had an issue with Edit and Win98 and Win2000 Pro: from my experience, that seems to be the way to fly.
LSs1Power - Yep, it works with XP no problem - my suggestion would be to pick a laptop that has a serial port built into it - that will guarauntee maximumm compatability (the usb adapters can work, but they can also be flaky at times)
My opinion is to get one now. All the newer models do not have a 9 pin port on them. By the way Compaq and HP are the same computer now.
Oh by the way guys, when u finish downloading the Flash file, what do u have to do after that to get LS1 Edit work? which program should i open the Flash file with?
Check out http://www.usedlaptops.com.
