160lb injectors
Old Oct 9, 2007 | 07:05 AM
Willem @ Fuel Injection Concepts's Avatar
Default 160lb injectors
Anyone nutty enough yet to try 160 pounders with an imp. box on the stock PCM? Just curious.
Old Oct 9, 2007 | 07:18 AM
Fireball's Avatar
I'm nutty enough and plan to try...but haven't gotten that far yet...
Since I am building a racecar, idle quality is not a factor for me (can have a pretty high idle speed if need be)
Old Oct 9, 2007 | 07:51 AM
depends on the CI too.. i've got a 427, so that should help with idle a little.. a 346 i can see flooding out potentially.
Old Oct 9, 2007 | 07:57 AM
Fireball's Avatar
I'm gonna be a relatively small 366 cid. I believe Harlan ran them with his "stock" pcm with his 348 setup back in the day...
Old Oct 9, 2007 | 08:46 AM
do you need a place to buy the injectors from? <<<< dealer
or the aem inj driver box?
Old Oct 9, 2007 | 08:58 AM
Fireball's Avatar
will consider once I'm ready to do the fueling/wiring of the car...need to get the hard parts finished first
Old Oct 9, 2007 | 02:36 PM
Nickn20's Avatar
hehe, biggest so far 96s for me. Honestly for 160s and the power level for them, it seems like one would step up to a more advanced fueling management system, say one with indvidual cylinder control, and EGT sensors. Don't get me wrong I'm all for making 2000 hp on a stock computer, but how reliable is it really going to be?
Nick
Old Oct 9, 2007 | 10:22 PM
Tomcat's Avatar
Have done it on a couple of cars now , the latest was a GTO that laid down 1130hp and is still a full street car.
We arent using 160 pounders but are close with a low impedance driver box to drive the injectors from the std PCM.
Old Oct 9, 2007 | 10:27 PM
Nickn20's Avatar
1130 rwhp? any details on this car?
Old Oct 10, 2007 | 03:43 AM
LSInnovations's Avatar
<---96lb/hr @ 1100 rwhp /w methanol
Old Oct 10, 2007 | 06:26 AM
Fireball's Avatar
sometimes its not the hp they can support, its the rpm at a high hp setup. 8000 rpm leaves a pretty small window for injection requiring a larger injector to reduce the duty cycle...
Old Oct 10, 2007 | 07:17 AM
just curious, what imp boxes are you guys using that posted in? FJO? AEM?
Old Oct 10, 2007 | 12:14 PM
Frost's Avatar
96's with the AEM box for me... racetronics sells a harness for the AEM unit now too.
Old Oct 10, 2007 | 09:58 PM
Tomcat's Avatar
There is a thread about it here http://www.ls1gto.com/forums/showthread.php?t=176182
or it can also be found here http://www.ls1.com.au/forum/showthre...=56108&page=13
With a lot of other blown stuff I do.
Old Oct 11, 2007 | 01:18 AM
Nickn20's Avatar
so thats with a YSI vortech?
Old Oct 11, 2007 | 01:47 AM
black98ws6ta's Avatar
I tried it with someone else tuning, it didnt run worth a ****, but it could have all been the tuner.
Old Oct 14, 2007 | 09:43 PM
Tomcat's Avatar
V7 maxed
Old Oct 14, 2007 | 10:47 PM
Slowhawk's Avatar
LS1Tech Sponsor
I helped someone tune in 160's's with a Versa fueller box.It didn't do too bad.We got it to idle at 11.5-1 A/F at 950rpm and 40psi of fuel pressure.Then would go 14-1 at 1400rpm.This was a 416ci/Turbo setup.I wouldn't start a new engine on them since it takes work to get them to idle.
Old Oct 15, 2007 | 09:31 AM
You're referring to flooding out the rings, i'm assuming?
