Logging injectors with hptuners
electrical pulse width. You can do an injector balance
test, and you can look at cylinder mode misfires to chase
individual injector problems, swap the suspicious ones with
good ones and see if the signature moves with.
I see a cylinder balance...is that what you are talking about?
RPM Ref: 1084 Idle (IAC) Control
#1: 978-90% RPM 1000
#2: 864-79%
#3: 850-78% Steps 17
#4: 982-90%
#5: 993-91%
#6: 994-91%
#7: 840-77%
#8: 785-72%
Could a vacuum leak cause this? Like if one or more of the intake runners were not properly seated?
a clean, bank-to-bank problem.
For misfires, you just want to log the Misfire Current Cylinder
1,2,3,...,8 and look at whether any of them stand out at idle
or low cruise or accelerating. Not so much the absolute number
as whether one or four of the cylinders are unusual.
Though if this has been going on long, maybe all clean plugs
is not a bad idea. Depends on whether they are "dirty" or
fouled enough to cause their own set of problems, whether or
not they were the initial trouble.
Four vacuum leaks on nonadjacent cylinders seems kind of
unlikely. But you can get some crazy trimming with only one
runner leak, and then over-enrich everybody else to "fix it".
How do you log cylinder misfires individually? I don't have any misfire codes, but when I give it gas, it sure does feel like there is a cylinder or two off. But then again, around 4k it doesn't seem bad.
And I put fresh plugs in it...problem still persists. I'm thinking about taking out my injectors and cleaning them. Can't hurt.
open up the table display that shows all the PIDs you're logging,
right click, insert: engine diagnostics -> misfire -> misfire current cylinder #
it'll use up 8 PIDs
after you drive around doing stuff that makes you think you have a misfire, save the log, but also "Export Data" (found under Scan in the toolbar). that will drop an excel file that you can work with.
i did this and found a miss that didn't trigger a code or that i couldn't feel - turned out a spark plug wire was loosening up.
Would someone mind looking at my scan to see if everything looks okay or if I missed anything.
Thanks for everyones help!
