Wideband Install
Old Oct 26, 2007 | 12:49 AM
exit's Avatar
Default Wideband Install
Im about to tackle this wideband install this weekend. I'm gona be installing the NGK AFX....it seems simple enough.
Just curious as to how you guys do the wiring.
For example. Where do you connect the power/ground cables?
Old Oct 26, 2007 | 11:48 AM
exit's Avatar
anyone?
Old Oct 26, 2007 | 01:01 PM
Lickeyman's Avatar
I was planning on using a switched accessory lead on my fuse panel by the door. Dunno if thats how your supposed to do it but thats what I am going to do unless I hear differently.
Old Oct 26, 2007 | 05:42 PM
99DWPTA's Avatar
i use my headlight switch. when its on halfway my gauges turn on
Old Oct 26, 2007 | 06:20 PM
1BADAIR's Avatar
my power comes from the keyed power outlet
Old Oct 27, 2007 | 01:34 PM
Jake@EPP's Avatar
Try the IGN socket in the cabin fuse panel. This is 12v while cranking.
Old Oct 28, 2007 | 09:02 PM
exit's Avatar
awsome, I'll do that! Thanks
Old Oct 28, 2007 | 09:10 PM
CamaroSS19's Avatar
I used the power formn the avalable port in the fuse box on the drivers side . I was also told that using power from cig lighter will scew the results
Old Oct 29, 2007 | 05:17 PM
blackztwty8's Avatar
if u use the cig lighter its a constant voltage...you don't want to do that
Old Oct 29, 2007 | 07:29 PM
1BADAIR's Avatar
1 is keyed 1 is constant
