gauges sweeping
Old Oct 29, 2007 | 06:16 AM
playboy245's Avatar
Default gauges sweeping
i just installed a l92 engine into my car and every time i go to start it the gauges all sweep to the highest then back down to the lowest then the tach is inop at all times every thing works after that, i have no clue whats going on please he me out guys!!!
Old Oct 29, 2007 | 07:14 AM
Eurospec2's Avatar
Need more info, what kind of car, what PCM, what BCM?
Some Gm's, spefically Corvettes, do the guage sweep on start up, its a functional test.
Old Nov 11, 2007 | 08:41 PM
playboy245's Avatar
the car is a 1999 chevy camaro z28, it was a mail order tune from texas speed
Old Nov 11, 2007 | 10:59 PM
Shallow Bay's Avatar
Does the trip odometer reset when this happens?
Old Nov 12, 2007 | 08:40 AM
NOBR8KSS's Avatar
I seem to recall that this was a problem with cold weather and the stock AC Delco battery. The batteries that came in that car were crap, and when cold weather came, the voltage dropped, causing the instrument cluster to jump into a "self test" mode. Replacing the battery should fix it.
JC
Old Nov 12, 2007 | 12:15 PM
sprayjunkie's Avatar
Yes, I had this exact issue in my 99 Z28 and cured it by replacing the battery.
Old Nov 12, 2007 | 12:21 PM
2formulas's Avatar
3rd for the battery, if you search my posts somewhere in there I had this issue, it was going around for a while. change your battery with the key OUT of the ignition.
Old Nov 13, 2007 | 12:15 AM
LS1IMPULSE's Avatar
are you certain you hooked ALL the ground straps back up? Grounds always cause odd little problems such as the one your speeking of.
