what is crank relearn?
that tells the ecu if its in drive park of neutral
and he said that in order to do something it needed to have that plugged in
http://www.gearchatter.com/viewtopic8817.php
https://ls1tech.com/forums/showpost....04&postcount=2
If you turn the code off in the PCM (which alot of tuners do) the misfire detection is still enabled.
