stupid HPTuners question
Old Nov 8, 2007 | 04:51 PM
magius231's Avatar
Default stupid HPTuners question
ok feeling stupid, but I searched and couldn't find this. I can't seem to find where the HPTuners scanner records IAC steps. I know it's there, I know you can add it to the gauges and the table view as IAC Position, but it never records anything , and I can't see where it records these anywhere else by default. Am I missing something? I can't get anything else to record on the gauges either if I add it...
Old Nov 8, 2007 | 05:01 PM
edcmat-l1's Avatar
Do you know how to insert pids in the table view?
Do you have too many bits of data already? You can find the bits at the bottom of the table view.
Old Nov 8, 2007 | 06:12 PM
magius231's Avatar
not in the table view I don't. used bits = 0, although Im not sure how that could be. I can right click on the table, but all the options are greyed out...
Old Nov 8, 2007 | 06:49 PM
edcmat-l1's Avatar
Dont sound right. Can you post or send me a screen shot? Whats greyed out? When you right click, can you choose insert/delete?
PM me if ya gotta. I'm going home in a few, I'll check back in about an hour.
Old Nov 8, 2007 | 07:02 PM
Frost's Avatar
close the log file you are viewing and then try it
Old Nov 8, 2007 | 07:42 PM
magius231's Avatar
ok that worked I can't hook it up until the morning though, will this start the logging for IAC, even though it wasn't logging in the chart or the gauge view?
Old Nov 8, 2007 | 08:57 PM
edcmat-l1's Avatar
Yes. It'll log it in the table view.
Old Nov 8, 2007 | 09:04 PM
foff667's Avatar
LS1TECH Sponsor
The table view is the only one that matters, its the primary view. If your not logging it in the table display you simply aren't logging it.
Old Nov 8, 2007 | 09:05 PM
magius231's Avatar
fair enough, thanks a ton everyone I'll get this going tomorrow and see what happens!
