Car tries to die at start up
Old Nov 19, 2007 | 11:56 PM
BlackSS2001's Avatar
Question Car tries to die at start up
I'm not sure if I picked the right area to post this in.
After I did the Cam install my car tries to die at start up. It tries to idle at 300-500 RPM then after a few seconds it goes up to 900 RPM like it's suppose to.
I haven't drilled out the air hole in the throttle body because I have heard that it can mess up the tune.
Any ideas?
Thanks.
Old Nov 20, 2007 | 12:45 AM
richard head's Avatar
leave the key in the on position for a few seconds before you try to start it? usually (after a pcm flash) I let the fuel pump prime up first and it works fine but if I don't then it idles rough as **** and tries to die.
Old Nov 20, 2007 | 09:34 AM
that doesnt help at all..
I had the dyno tune a few months back and its still doing this
Old Nov 22, 2007 | 02:43 AM
bump!!
Old Nov 22, 2007 | 08:08 PM
edcmat-l1's Avatar
Needs to be tuned. If it has been tuned, it needs to be tuned by a better tuner.
Old Nov 24, 2007 | 03:47 AM
I had it at TSP on the dyno and got a tune on it then..
Old Nov 24, 2007 | 04:38 AM
Frost's Avatar
sure we can help you with your car... provided you have some tuning software. Yo DO have some software right, I mean you are asking for help here in the tuning forum for what is clearly a basic tuning issue... You can see how it would be hard to have your cold startups nailed on a tune on some dyno after all, how many cold start opportunities can you have on the dyno to test this? Yeah, none.
Assuming so (that you have some software), you need to increase the startup airflow @ whatever temp you are having weak starts. Also, turn the camshaft delay for decay to some higher number like 12-16 or something. You can use the friction air or startup air table, they both just add to one another anyway.
Old Nov 24, 2007 | 07:30 AM
Rhino79's Avatar
Ditto, try adding about 3-4 g/s air in the Startup airflow friction table, you should be set then.
Old Nov 25, 2007 | 09:30 PM
a buddy of mine has the newest HP tuner program.
It's not just on cold starts its on all of them. cold hot whatever.
Old Nov 25, 2007 | 10:10 PM
edcmat-l1's Avatar
Have your buddy post your tune and a start up log. We'll getcha cured. Theres plenty of people on here that can get ya straight.
Old Nov 26, 2007 | 10:26 PM
to be honnest I dont want a bunch of people that might just think they know what there doing start sending me files that will "fix" my car..
Old Nov 26, 2007 | 10:53 PM
Rhino79's Avatar
Startup friction airflow is the table to remedy the start stumble and die syndrome. It adds airflow only on startup, and decays the air back out smoothly over a short period of time.
Old Nov 27, 2007 | 09:31 AM
edcmat-l1's Avatar
Ok, sooooo, you want ideas, but you dont want ideas? Theres only about a 1/2 dozen people on here that will even take a stab at it. My feeling is, and the guys on the HPT forum will tell you the same, if ya want help, ya gotta post your tune and preferably your tune and a run log.
Old Nov 27, 2007 | 09:58 AM
Frost's Avatar
suits me, fix it yourself
Old Nov 27, 2007 | 03:07 PM
I'm just saying I've had enough problems and I don't want any more. If you guys know what your doing then hell yeah I need your help, but also there are a lot of people out there than just think they know what there doing but really don't. Just because you have the tuning program doesnt mean that you know what your doing, you know what I mean?
Old Nov 27, 2007 | 04:42 PM
Frost's Avatar
yeah it hit me the wrong way I guess, no harm
don't take a file, copy the text of what I (and others) told you to change, get your buddy's setup and read your file. Change what you wrote down from here and see that it fixes it. If it's still weak, add more air, if it revs up too high, take some away. Do it yourself and see the effect. Also know that there is a delay and a decay for that airflow adder. The delay is how long it holds at the value you have placed in the table before the decay begins, which is it tapering off. A less aggressive decay will bring it down slower.
DIY and see it for yourself.
Old Nov 27, 2007 | 06:48 PM
Thanks a lot!
also a inportant bit of info I forgot to add. The car runs really rich. It throws flames out when I shift and you can smell the extra gas in the exhaust.
I'll get one of my dyno sheets up on here also. I have a couple of start up and driving files that I will try and get from my friend so I can get them up on here so you can see for yourself what the car is doing.
Old Nov 27, 2007 | 07:58 PM
edcmat-l1's Avatar
Thanks a lot!
Thats a very telling statement. It probably means the VE needs dialed in. That will make it start alot better too. Typical of a not very thorough tune.
Old Nov 27, 2007 | 09:41 PM
DaveX's Avatar
It needs idle/driveability tuning. Dyno tuning usually only addresses wot/pe mode for the most part. It can take some time and know how to get it dialed in for good street manners. Mine is the first one I've done and it took me a few months of nights and weekends to get it decent.
Old Nov 27, 2007 | 10:46 PM
Frost's Avatar
Yeah +1... if the VE table is stock from 1K and down, it's gonna be so fat in open loop that the airflow additions are not the solution.
