IAC Count is too Low?
Old Jun 20, 2003 | 11:11 PM
IRVINEWS6's Avatar
Default IAC Count is too Low?
My IAC count (steps) are o at idle. Will performing the drill mod increase or decrease the IAC?
'00 WS6, M6
MTI stage II heads, milled .030", B1 cam (220/220 114), LT's, Y-pipe, free flow cats, Borla, underpulley, 180* stat, Whisper lid.
Old Jun 20, 2003 | 11:48 PM
StevieZ's Avatar
Default Re: IAC Count is too Low?
Drilling will decrease.
Old Jun 21, 2003 | 01:33 AM
andy98Z's Avatar
MOst likely intake leak.
Old Jun 21, 2003 | 01:08 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Sure it's not because of this, https://ls1tech.com/threads/showflat...14&fpart=1 ?
Old Jun 23, 2003 | 10:35 AM
killer01ws6's Avatar
This would be my quess too.
Old Jun 24, 2003 | 03:27 PM
eallanboggs's Avatar
IAC counts to LOW? That's a new one. It's usually just the opposite. IAC at "0"? Too much air getting in at idle with throttle butterfly fully closed. That's an air leak unless your IAC is defective or disconnected. You better check your work again. Try plugging the IAC connector back in and check it with AutoTap again to see if the counts jump up.
Old Jun 24, 2003 | 04:12 PM
Smoke_Ford's Avatar
Yeah, usually you want your IAC to be between 20 and 30. After cam, if no intake leak, they are around 80 depending on cam. Drill mod lowers them.
Old Jun 24, 2003 | 07:39 PM
Viper's Avatar
AzzHauler may be right; what are you running to read the values?
Old Jun 25, 2003 | 12:13 AM
Ed Blown Vert's Avatar
What version of ATAP are you using?
Old Jun 26, 2003 | 10:58 AM
Red12secZ28's Avatar
If your using autotap 2.03 & 2.04 then the iac counts don't work. They just stay 0. I had to uses EFIlive in unregistered mode with my atap cable to check my iac counts.
Old Jun 26, 2003 | 12:12 PM
Can't you use the Desired IAC?
