Issues with knock.
Old Dec 4, 2007 | 08:55 PM
OMGWTFBODY's Avatar
Default Issues with knock.
Car is a 98 LS1 that just turned 100k miles.
Since I picked it up, its had an EGR code and a knock sensor low voltage code.
Just seafoamed the engine a few weeks (3) back.
What might cause the knock sensor to knock the timing back 4 degrees and set a 'low voltage' SEL Code?
Old Dec 18, 2007 | 08:31 PM
OMGWTFBODY's Avatar
Removed EGR, Codes Deleted, tuned to suit. (HP Tuners)
Intake removed, knock modules look like crap. Removing and replacing.
Code P0327 still present.
Replaced both Pre-cat O2 sensors.
-Bank one showing less than nominal.
Old Dec 19, 2007 | 09:08 AM
jimmyblue's Avatar
Moderator
'98 knock sensors are notoriously bad, see how
it goes after R&R.
If EGR is defeated or just not working there will
be excess timing at some part throttle regions,
where the tune counts on the EGR pissing on the
campfire.
Old Dec 19, 2007 | 06:23 PM
Lickeyman's Avatar
Make sure your maf is clean cause that can cause inconsistent fueling issues.
Old Dec 19, 2007 | 07:02 PM
OMGWTFBODY's Avatar
The code is from the first knock sensor. It is completely rusted out. I ordered a new one today. The second one looks alright, and wasn't throwing codes, so I'm going to put it back in. I would replace both, but at this point I can't afford it.
Looks like the rust on the sensor may have been the issue.
Any recommendations as to how to properly seal it? I'm thinking a strip of hightemp RTV around the rubber seal on top to help keep moisture out.
MAF is clean, as are intake and throttle body.
The EGR is off, I should have the plates Friday when I run it again. I have a local fellow running HP tuners to account for timing differences.
