LC1 wiring
http://www.audiohelix.com/tuning-documents/lc1/lc1.htm
Also, if that's the case, can I just run the red 12V switched wire to the D slot? If my assumption on letters and what they do are WRONG please tell me. I think I've finally got this, I have the sensor routed and ready to calibrate, just need to run these wires then I'm all set. If my question is unclear LMK I'll try and reword. Thanks.
-J
The LC-1 is very sensitive to its power and ground sources...so I made extra sure to give it a fighting chance by finding the best power and grounds I could.
-J
The most important thing you can do if you are logging the LC-1 through an interface of some sort is to make sure the Innovate software and your tuning software agree on what the AFR is. As long as they both agree (and the LC-1 works without a hiccup), it doesn't matter where you have it wired.
HP Tuners get very upset if you route a heater ground through their MPVI, so that attached worked for me. One diagram before connecting to scanning tool, one diagram after connecting to scanning tool.
Good luck.
