LC1 Problems
I have the red controler wire and brown display wire going to a switched 12v source in the fuse box. The blue controler wire goes to a dedicated ground pole under the driver kick panel. The yellow controler wire is connected to the black gauge wire.
The blue gauge wire and the white controller wire go to a common ground on my shifter. The black controller wire is connected to the diode and button and then grounded to the same place as the blue and white wires.
I've rechecked all of the wiring connections and performed the free air calibration 3 times.
When I turn the key to ignition on (car off) the gauge reads 1.0 - 0.8. After calibration this does not change. When going through the trouble shooting procedure it tells you to remove the sensor and check for about 00.0 in free air. This never occurs. Then it tells you to unplug the black connector and check for 50.0. This never occurs.
With the sensor unplugged from the controller I see around 1.0 on the gauge. In testing all of my connections I moved the ground for the white and blue wires and the gauge stayed lit with them not grounded. I seperated the diode ground and the blue/white grounds. No changes in readings and stayed lit at 1.0.
I could never get it to read 50.0 with the sensor unhooked. When the car was running after start up it was erratic from 1.0 to 6.5 on the gauge. Then it would settle on 1.0.
Any ideas?
and it maybe toast now that it has been connected to 12 volts.
red = 12 volt
blue = ground
yellow/brown = analog output 0v-5v
green = analog ground
white = system ground
remove the brown from 12 volt source,
recalibrate the sensor.
program analog #2 with the LM programmer
to a flat voltage and use a voltmeter
to see if it is dead.
Depending on the gauge you are using, the brown (0-5v analog out) or yellow (0.1-1v analog out) controller wire should be used as the input, and the gauge ground should be grounded in a common location with the blue (heater ground) and white (system ground) wires.
The blue, white, black, and gauge ground should all be in a common location; voltage differences between the ground will cause a false signal. It's also advisable to solder all connections. I didn't think this was important when I installed mine and wound up with erratic readings. I removed all my wiring and soldered everything (rather than crimping) and have had no problems since.
Make sure your pushbutton switch isn't shorted for some reason and that the 1/8in terminator is securely inserted into the IN connection. If you insert/remove the 1/8in jacks while the unit is on, the configuration will be messed up.
If you can, get a computer nearby and use the LW2 program to watch what the sensor is doing upon key-on. If your analog wiring is incorrect, this will also show you if you are reading free air or not.
red = 12 volt
blue = ground
Since everything is still apart, I might pull it out and solder it while I have a chance. Should I give them a common chassis ground? Use the pole under the drivers side kick pannel that the controller ground currently goes to?
Thanks.
Thanks.
If your going to ground them to the body eather use 1 lug and 1 bolt for all the grounds or use seperate bolts and lugs for each ground, but put all the grounds as close to each other as possible. puting 2 lugs on 1 bolt is a no no!
Thanks.
If the ground point you are using for the heater is "greater" than the ground you use for the system, you wind up with current flow between the heater ground and the system ground going through the circuit. Because the referenced "zero volt" used for the analog out is not truly "zero" anymore, you wind up with skewed readings. Common grounds between the gauge and the system (white) are more important than a common ground between the heater and everything else, but you still don't want current running through the controller.
Ideally, you want to ground everything to the block or head, as above, either all on one lug, or separate lugs near each other. This will reduce the likelihood of some kind of current spike happening from the starter or something (allegedly). Some people claim that you can wind up with these spikes by using a ground under the dash; I don't know if this is true, but it didn't apply to me as I have the controller under the car anyway. I would ground it to the chassis, or block/head if possible.
For what it's worth, I hacked up an old NBO2 harness and used the grounds there for the controller, as I needed to be able to move the LC-1 between different vehicles. The grounds go to the engine/block anyway, so it just saved me some wire and still works well.
Sorry for the long post. I have seen a lot of people ask why they can't have separate and distant grounds, but no explanation why, except for "don't do it." Hope this helps.
Sorry for the thread Hi jack.
I guess I will pull the grounds apart and make a common ground for them. As I understand the posts, I need to have all the ground wires go to one common hoop style ground that goes over one single ground post? And if possible the single ground should be the engine block over a chassis ground (the ground poles under the kick panels and center console are chassis grounds).
I will make the changes tomorrow. Thanks
Any ideas?
