VE value is 0 and LTFT is -10. What's wrong?
Any help would be great.
I'm a poor college student. $300 for a wideband can buy SO much food and alcohol, it's not even funny
The MAF is in fact disabled. MAF fail frequency = 0.
Anyways, here's the tune. I didn't save the log, so I'll get a new one up when I can.
Set up your histograms to plot the primary and secondary VEs at the same time.
Also, need to disable LTFT and use STFT.
Injectors? 42 SVOs I assume?
One more thing. I would zero the MAF table, as I'm not sure setting the fail to 0 completely eliminates it. I've never tried just that.
Set your P0101, 102, 103 to no MIL.
May wanna copy over the idle area of the low octane table to the idle spark table, so they are the same.
I think thats about it.
1. disable LTFTs in the editor
2. BEFORE logging ANYTHING, in the scanner, with it hooked up and scanning, reset fuel trims and this will zero them out. If not, it's gonna apply that -10 in the same place it always has, even if it doesn't need it.
Also, as Ed mentioned, make sure to copy everything over to your secondary VE, as that is what you are running off of in SD.
Also the maf was failed at zero, but I think you still need to zero out the table. So I did.
Try this one. I redid the VE a little bit, and copied it over to your secondary table.
You had a dip in it, but it doesnt look like its in the right place, and the 400 column was too rich.
Load this one, and like frost said, turn the scanner on and reset the fuel trims. I've disabled the long terms. Use the short terms and the histogram to dial in the VE. Or, if you have a wideband, you can use A/F error.
