Torque Management / HP Tuners - How Do I Get Around The 640 ft-lbf Limit?
640 ft lbs is the max legal torque the PCM will allow. We are hitting 640 ft-lbs and the timing is defaulting to 10 degrees despite being commanded a higher value. How do we get around this using the HP Tuners software?
Thanks,
Sean
Thanks,
Sean
i would try setting the min spark table at that rpm to your desired spark advance.
hope this helps,
volkan
